03-11-2010, 18:22 | #1 (permalink) |
Junior Member Join Date: Mar 2010 Location: Romania Age: 43
Member: 1253967 Status: Offline Thanks Meter: 2 | Can i unlock 1661 with mxkey ? rh-122 nokia 1661 when i make update sp lock i receve an error message this is phone info: Version Info: MCU SW version: V 04.30 06-07-09 RH-122 (c) Nokia HW version: 1003 UEM version: 1328 UPP version: 8851 RFIC version: 0700 DSP version: ICPR81_09w17_U LCD version: WIN:BOHAIv91 NT39121 PPM version: V 04.30 06-07-09 RH-122 (c) Nokia EE ADSP SW version: p V 04.30\n06-07-09\nRH-122\n(c) NMP\nee Product Info: Production serial number: HMG843015 Product code: 0587570 Module code: 0204019 Basic production code: 0591753 Serial Numbers: IMEI plain: 359328030608527 IMEI spare to net: 3A 95 23 08 03 06 58 02 IMEI SV to net: 33 95 23 08 03 06 58 32 F0 Other Info: CS type : GSM/DCS1800 BSI: 4.8 KOhm Imei net: 35932803060852 Version: SIMLOCK SERVER Provider: Retevision Movil Amena, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140300000000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 21403F after update simlock i receve this: Imei net: 35932803060852 Version: SIMLOCK SERVER Provider: Retevision Movil Amena, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140300000000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 21403F PhoneType:RH-122 SwVersion: V 04.30 06-07-09 RH-122 (c) Nokia MCU file: rh122_004.300 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00ED0338:2984DA60 Area [01000000-0101FFFF] erased in 0.688 s Area [01160000-0117FFFF] erased in 0.672 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x14 what this error mean ? i must write PM file? if this did someone have PM file for this? |
Can i unlock 5233 with mxkey | .RAM | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 09:55 |
How to flash 1202,1661 with mxkey | noushadpnoushad | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-22-2010 16:40 |
Can i unlock 1661 rh-121 with Genie Universal????? | lihua | Genie Universal | 20 | 03-16-2010 12:21 |
Can i unlock 1661 rh-121 with mxkey ? | lihua | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-12-2010 19:15 |
how can i wright rpl with mxkey | saajith | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-23-2009 22:00 |
