Old 08-09-2010, 11:57   #1 (permalink)
Member: 545565
Thanks Meter: 19
5130 contact service not done
Sir.
i have 5130 i tried it but it shows:
If please tell me the steps
Thank you
Details:
Imei net: 354179036753535
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Product: V 05.80 18-12-08 RM-495 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
Calculating SIMLOCK using security server ...
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
Completed in 9.578 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-495_354179036753535_SIM.RPL"
Updating SIMLOCK...error 0x1
Reading Simlock info ...
Counter: 0/3, 0/10
Old 08-09-2010, 12:18   #2 (permalink)
PedaLBoard's Avatar
Member: 1317565
Thanks Meter: 61
if you are trying to update splock, 5130 is not yet supported for what you are trying for.
if your phone is security_test_failed! you can repair it to SX4..
buscheck your phone and post here the full logs
Old 08-09-2010, 12:48   #3 (permalink)
Member: 545565
Thanks Meter: 19
logs
Please reply
thank you for last reply
logs:
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 03C00102EFAC7D56343CDA606102E85273FDCDCA
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Original Imei: 35417903675353
Original Product code: 0577793
Bluetooth ID: 0025482F7AF9
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 05.80 18-12-08 RM-495 (c) Nokia
Imei plain: 35417903675353-5
Product Code: 0577793
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Counter: 0/3, 0/10
Old 08-16-2010, 11:04   #4 (permalink)
Member: 1299960
Thanks Meter: 36
goto pm-load pm file that has field 1 and 309, do pmm auth or super sd and then write
Old 08-16-2010, 12:05   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
SIMLOCK_TEST passed
if you get this,
only need PM Auth and WR PM [1]&[309]
br,
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
how to unlock 5130 accelr8 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-24-2010 17:52
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.16287 seconds with 9 queries
