Old 06-26-2010, 08:28   #1 (permalink)
Member: 608370
Thanks Meter: 89
5220 dead by downgrade
i have 5220. it has been dead by downgrade. now i am trying with usb cable. but it is giving me following error:
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Processing file: rm411__07.23.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 19.92 MB
Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Polling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1E3158CB
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000295
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 23800109ADA10254C6E6FE46133266084816ED83
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4AF40 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
Flashing terminated with error(s) in 23.328 s
Nokia USB ROM detached.
Nokia USB Flashing Generic ready.
how can i revive my phone? great masters are requested to help
Old 06-26-2010, 10:44   #2 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
@prime_master786
Whats probem was before flashing/downfrading ?
Try to recover handset with Fbus.
Br.
Shashank
Old 06-26-2010, 13:41   #3 (permalink)
Member: 608370
Thanks Meter: 89
Originally Posted by shashankmobile View Post
@prime_master786
Br.
Shashank
Dear,
set was restarting but other technician flsahed it with lower version, set owner told me
Old 06-26-2010, 13:43   #4 (permalink)
Member: 20038
Thanks Meter: 19
usb cannot repair it.. use fbus.. but i thing your phone need new bootloader.. i suggest that u use atf as interface fbus..
br
merdekha
Old 06-26-2010, 17:52   #5 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Bro, dont worry, let me try to help you. One thing you should know is that after downgrading, your phone will not be able to enter another mode( local, test, normal etc) and when you switch on, it will stop at Nokia Handshake logo. Te repair it, first flash your phone with your desired firmware with fbus. After complete flashing, Go to Service->Quick Fix and then select BB5 SW downgrade Fix and click Do selected Jobs. I am sure 99% your problem will be solved. (yes, that 1% maybe something i don't know, i dont say 100% like others because i am not the one who knows everything)
Old 06-27-2010, 05:34   #6 (permalink)
Member: 608370
Thanks Meter: 89
Brother,
it does not hang on nokia handsheke logo, it is fully dead.
i have also tried with fbus cable with hwk and mxkey>
mxkey log:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.891 s
CMT NOR area [000006C0-0001FFFF] erased in 0.250 s
CMT NOR area [00040000-000BFFFF] erased in 0.312 s
CMT NOR area [000C0000-0013FFFF] erased in 0.266 s
CMT NOR area [00140000-0137FFFF] erased in 4.359 s
CMT NOR area [01380000-0151FFFF] erased in 0.578 s
Flash programming ...
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00040000, Result: 0010
Flashing terminated with error(s) in 41.578 s
RX Buffer: C7012D0103CD000010000000F172
hwk log:
1ST BOOT : C0,07 [Rm-411] [2.1.0.1]
RAPx ID : 000000010000022600010006030C192101033000
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx PBID : 23800109ADA10254C6E6FE46133266084816ED83
RAPx MODE : 00
RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
RAPx ROID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00898982-00008A31, Int NU48F512
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm411__07.23.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00040000-000BFFFF
CMT NOR Erase Area: 0x000C0000-0013FFFF
CMT NOR Erase Area: 0x00140000-0137FFFF
CMT NOR Erase Area: 0x01380000-0151FFFF
CMT FLASH ERASE OK, Time: 00:05
DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable !
DATA_BLK_ERROR at: 0x00040000, 03
ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x000240, Time: 00:09
Process Failed, Repowering Mobile
Old 06-27-2010, 06:48   #7 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
brother flash agin and Go to Service->Quick Fix and then select BB5 SW downgrade Fix and click Do selected Jobs
Old 06-27-2010, 07:23   #8 (permalink)
Member: 1225482
Thanks Meter: 45
bro try full erase then full flash w/ high version,,,
Old 06-27-2010, 14:24   #9 (permalink)
Member: 608370
Thanks Meter: 89
Brother check this, what can i do more????????????????????
Old 06-27-2010, 16:19   #10 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
bro 1st usb flash by PHOENIX software 2nd Go to Service->Quick Fix and then select BB5 SW downgrade Fix and click Do selected Jobs
Old 06-27-2010, 16:35   #11 (permalink)
nepoleanl's Avatar
Member: 836540
Thanks Meter: 71
man just full erase it and flash it again with the new version
will be 100% ok no other solution will help you
Old 06-27-2010, 16:48   #12 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Brother,
mxkey log:
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
hwk log:
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
ok, Did you use 7 pin fbus cable? if not use it, if you already use it, then try to flash again with option skip erase enabled. If you still have problem, put a little heat on the flash ic and try it again. Best of luck bro.
BR,
curvenger
Old 06-27-2010, 16:56   #13 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Lol, never do a full erase if you dont have backups, or else you will end up with IMEI 123456789?, if you want to do full erase, at least make a backup of NPC cert first.
BR,
curvenger
Old 06-27-2010, 18:49   #14 (permalink)
nepoleanl's Avatar
Member: 836540
Thanks Meter: 71
BR,
curvenger
back up before erase thats a common knowledge man
Old 06-27-2010, 18:58   #15 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Look at the log bro, do you think its possible to make backup before erase???
I have 5.28 unlocker by cable. GreEn Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 15 07-13-2000 21:57
5.28 working solution by eeprom 24x16 SLO/EU Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-22-2000 15:55
nokia nse-spv8 by zulea rothmanns Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-12-2000 07:52
have nokia lock 2 solution by cable oskarcore Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-29-1999 22:49
Page generated in 0.36560 seconds with 10 queries
