06-29-2009, 01:39 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 53
Member: 4611 Status: Offline Thanks Meter: 68 | Cannot flash By USB..Always the same error "cannot create file c:\mobileex\3.2\<". The filename, directory name, or volume label syntax is incorrect". What am I doing wrong? |
06-29-2009, 07:50 | #5 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | if you connect alive handset, you will get that phone in list. if you want to flash a phone in dead state. you ve to connect through Nokia USB ROM. |
06-29-2009, 08:01 | #6 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Thanks for the reply. Plugged usb into the handset, selected pc suite. clicked the drop down on mobileex, selected N95 usb generic 23953fa2. Can read everything that I need from the handset. Get the error when I try and flash. Bus check works fine. Tried the nokia com connection (just for the hel1 of it) get a different error when I try anything with the handset connected in pc suite mode. I know its probably something I've done, but cant put my inger on it. I've used jaf, ufs, universal box, mt-box, and even AFD by B-Phreaks...All without issue. |
The Following User Says Thank You to Blartiartfast For This Useful Post: |
06-29-2009, 10:36 | #7 (permalink) |
Member: 319447 Status: Offline Thanks Meter: 4,949 | Actually MX Key still not perfect for USB Flashing. Need a lot of modification in their USB Flashing. So, i would request. please give them some time for fixing this issue In the mean time be happy with old tools. Phoenix like me |
06-29-2009, 10:54 | #8 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Ha.. Sussed it.. Un installed it again, installed the oldest version I could find, then installed the new release.. All works well. Thanks for the help |
06-29-2009, 11:15 | #9 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Edit that.. 3.2.1 works like a charm.. There must be a bug in the latest release. 3.2.1 flashes perfectly everything that i've thrown at it. With the latest, back to the original error. |
nk5630,6700 cannot flash by usb | ahmad5175 | Nokia Base Band 5 ( BB-5 ) | 4 | 11-21-2009 03:48 |
n96 cannot flash by usb | ahmad5175 | Nokia Base Band 5 ( BB-5 ) | 3 | 10-13-2008 18:18 |
Canīt flash bb5 6680 always the same problem | al0342p | Universalbox | 7 | 04-28-2006 13:31 |
