10-12-2011, 09:28 | #1 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | Can't flash HIT box using Fbus cable. MXKEY [FT SCR2000 0], SN: C0xxxxxxx Using device: HTI, FW ver: 00.24, SN: 0000xxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011) Do not disconnect or abort this operation otherwise phone will be damaged. ERROR: could not boot device. |
10-12-2011, 09:42 | #2 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Here is old software using UFS interface Fbus flashing Mxkey 3.4 rev 2.1 logs. Backup saved to C:\mobileEx\3.4\data\backup\XGOLD_RM-653_96CB766206F002E2_IMEI.back MXKEY Serial: [FT SCR2000 0] - C0xxxxx Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.1.5.0, NTMP ver: 2.4.16.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 00EC 227A [Samsung ] Processing file: rm653_005.050 Downloading item CODE:hw_b2_rm653_r05.050.fls, num block: 3, size: 4.09 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 30.469 s Erasing area 0x00C60000-0x00E6607E ...OK Programming completed in 31.156 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.140 s Checksum verified (0x86ED) Processing file: rm653_005.05ia Downloading item CUST:hw_b2_rm653_005.05ia.fls, num block: 1, size: 1.95 MB Erasing area 0x00210000-0x0040377E ...OK Programming completed in 29.922 s Checksum verified (0xF00B) Processing file: rm6530_nai05.05ia Downloading item CUST:hw_b2_rm6530_nai05.05ia.fls, num block: 1, size: 334.02 KB Erasing area 0x00EB0000-0x00F02AFE ...OK Programming completed in 5.000 s Checksum verified (0xE8AC) Total time for flashing process(boot+erase+write) was 2 min 50.359 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RM-653 SW Version: V 05.05 24-05-10 RM-653 (c) Nokia Imei plain: 3534120xxxxx4-7 Product Code: 0594992 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei net: 3534120xxxxx14 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
10-12-2011, 10:10 | #5 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | My box is a picture of no-2 When I replaced the transistor and two resistors added Now reading and working without errors check fbus cable to provide power outputs close 5v transistor u have in Hard disk drive pc Tell someone you know who's output voltage for u box.. |
10-12-2011, 10:11 | #6 (permalink) |
10-12-2011, 10:16 | #7 (permalink) |
10-12-2011, 10:42 | #8 (permalink) |
No Life Poster Join Date: Sep 2009 Location: K'dua , 3rd Fl Main K'si St GH
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | @irfanamin2, all solution for repair of your mx box is here, follow steps and repair it. http://forum.gsmhosting.com/vbb/f550...fault-1325626/ |
10-12-2011, 10:42 | #9 (permalink) |
11-06-2012, 12:22 | #11 (permalink) |
Junior Member Join Date: Jun 2010 Location: badin pak
Member: 1322456 Status: Offline Sonork: [email protected] Thanks Meter: 1 | MXKEY [FT SCR2000 0], SN: C08444AE Using device: HTI, FW ver: 00.50, SN: 00000283 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) ERROR: could not boot device. plz help me |
11-06-2012, 17:21 | #12 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
The Following 6 Users Say Thank You to .::MASTER ALONE::. For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
fbus-mbus | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-05-1999 13:46 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
