03-27-2010, 08:21 | #1 (permalink) |
Major Poster Join Date: May 2007
Member: 511506 Status: Offline Thanks Meter: 5 | Cao! mobileEx 3.3 (rev1.7_fixed) NK5030 can not FLASH! HWK you can use! BootLoader not responding,mostly RAM problem! Flashing terminted with error(s)in 46.281s RX Buffer:F372 HWK you can use! Detected: V 03.75 21-04-09 RM-524 (c) Nokia 1st Boot: Ok, DCT4, UPP: 2293 [Rm-524] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x017FFFFF,002088C0,St M28W640 Algorithm: u3_st_i.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84588DFCEB4915603447EBF43C Decoded MSID: 3E4EBAE9-008CF175-A9000000 Encoded FAID: A4BEBB3A-EDF52E0E-39AB2B47 IMAGE: rm524_003.750 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x0179FFFF Erased, Time: 01:50 Area3: 0x017A0000-0x017EFFFF Erased, Time: 00:04 Area4: 0x01F00000-0x01FDFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:16 IMAGE: rm5240_nai03.75qa Area1: 0x01750000-0x0178FFFF Erased, Time: 00:04 CNT Flashing Completed, Time: 00:01 Running: Server fake reply for CUI phone. Contents Package Extracting Ok, Time: 00:10 1st Boot: Ok, DCT4, UPP: 2293 [Rm-524] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x017FFFFF,002088C0,St M28W640 Algorithm: u3_st_i.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84FBFA8999CC51DD0CD77577FC Decoded MSID: 3E4EBAE9-008CF175-A8000000 Encoded FAID: D2B8C145-839CA067-2A427D5A IMAGE: rm524_003.75qa Area1: 0x01250000-0x0125FFFF Erased, Time: 00:00 Area2: 0x01260000-0x0174FFFF Erased, Time: 01:10 PPM Flashing Completed, Time: 00:15 Flashing Completed, Rebooting Mobile UI Defaults Ok, Time: 00:05 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:01 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 All Done, Time: 04:35 |
03-27-2010, 08:27 | #2 (permalink) |
Freak Poster Join Date: Dec 2009 Location: ifixedcellution.blogspot.com
Member: 1190236 Status: Offline Sonork: 100.1589642 Thanks Meter: 233 | And this is another problem i encountered mostly in bb5 phone model it ends here Code: BootLoader not responding,mostly RAM problem! Flashing terminted with error(s)in 46.281s RX Buffer:F372 |
03-27-2010, 09:41 | #4 (permalink) |
Member: 511506 Status: Offline Thanks Meter: 5 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! Flashing terminated with error(s) in 46.281 s RX Buffer: F372 UFS3 SarasSoft disconnected. |
03-27-2010, 09:44 | #5 (permalink) | |
Freak Poster Join Date: May 2007
Member: 507861 Status: Offline Thanks Meter: 69 | Quote:
4shared.com - online file sharing and storage - download 3.3 rev 1.7 fixer.exe | |
03-27-2010, 10:59 | #6 (permalink) |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | http://forum.gsmhosting.com/vbb/f550...9/#post5614503 this problem is stil here .......... some perfect and permanent solution? |
MXKEY v3.3 revision 1.7 can not flash use jaf | boysam | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 03-22-2010 02:57 |
N70 can not flash by HWK | blackcat4780 | HWK | 11 | 04-25-2009 05:16 |
WHY can not flash se w600 BROWN49 on HWK | tsyx | HWK | 0 | 11-25-2008 04:47 |
Hwk Killer After Pacth Can Not Flash Bb5 And More... | tanalong | Twisterflasher | 1 | 06-12-2006 14:17 |
UFS-3 can not flash N 8310 | hoangminhtam | UFS2 + UFS3-Tornadoflasher | 2 | 06-30-2004 09:09 |
