03-02-2010, 07:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | check this 3110c contact service SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! WHEN PM AUTH Authenticating using security server ... Connecting to server[main.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request THEN REPAIR SIMLOCK REPAIR SD SUPER SD AUTH WRITE MODIFY PM PROBLEM REMAIN SAME SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! |
The Following User Says Thank You to rakesh15 For This Useful Post: |
03-02-2010, 07:47 | #2 (permalink) |
Freak Poster Join Date: Sep 2007 Location: On Muhammad's Way
Member: 597789 Status: Offline Thanks Meter: 147 | edit your rpl............. http://forum.gsmhosting.com/vbb/showthread.php?t=920409 |
03-02-2010, 08:14 | #3 (permalink) |
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | AFTER THAT MAKE HWC AND CCC THEN REPAIR SD SUPER SD AUTH WRITE PM ITS GOT OK SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed BUT AFTER FEW SECONDS SAME PROBLEM SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! I ALSO TRIED THIS http://forum.gsmhosting.com/vbb/show...36&postcount=1 EVEN ERASE FLASH WITH BB5 ERASE FILE BUT PROBLEM REMAIN SAME |
3110c contact service | zultopo | Nokia Base Band 5 ( BB-5 ) | 5 | 10-29-2010 11:33 |
3110c contact service and imei error | volmax® | MT-BOX | 10 | 04-18-2009 13:11 |
3110c Contact Service | zahed1978 | Nokia Hardware & Hardware Repair | 7 | 12-27-2008 21:13 |
