check this yall Imei net: 01149800283671 Version: SIMLOCK SERVER Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 310160 BLOCK 2: 1.LOCKED (MCC+MNC): 310200 BLOCK 3: 1.LOCKED (MCC+MNC): 310210 BLOCK 4: 1.LOCKED (MCC+MNC): 310220 BLOCK 5: 1.LOCKED (MCC+MNC): 310230 BLOCK 6: 1.LOCKED (MCC+MNC): 310240 BLOCK 7: 1.LOCKED (MCC+MNC): 310250 BLOCK 8: 1.LOCKED (MCC+MNC): 310260 BLOCK 9: 1.LOCKED (MCC+MNC): 310270 BLOCK 10: 1.LOCKED (MCC+MNC): 310310 BLOCK 11: 1.LOCKED (MCC+MNC): 310580 BLOCK 12: 1.LOCKED (MCC+MNC): 310660 BLOCK 13: 1.LOCKED (MCC+MNC): 310800 BLOCK 14: 1.LOCKED (MCC+MNC): 310490 Calculating SIMLOCK RPL using security server ... and thats all is this server problem? |
bro what is your problem past all logs here don"t wary servar are busy |
Imei net: 01149800283671 Version: SIMLOCK SERVER Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 310160 BLOCK 2: 1.LOCKED (MCC+MNC): 310200 BLOCK 3: 1.LOCKED (MCC+MNC): 310210 BLOCK 4: 1.LOCKED (MCC+MNC): 310220 BLOCK 5: 1.LOCKED (MCC+MNC): 310230 BLOCK 6: 1.LOCKED (MCC+MNC): 310240 BLOCK 7: 1.LOCKED (MCC+MNC): 310250 BLOCK 8: 1.LOCKED (MCC+MNC): 310260 BLOCK 9: 1.LOCKED (MCC+MNC): 310270 BLOCK 10: 1.LOCKED (MCC+MNC): 310310 BLOCK 11: 1.LOCKED (MCC+MNC): 310580 BLOCK 12: 1.LOCKED (MCC+MNC): 310660 BLOCK 13: 1.LOCKED (MCC+MNC): 310800 BLOCK 14: 1.LOCKED (MCC+MNC): 310490 Calculating SIMLOCK RPL using security server ... i wat to unlock this fone but it cant ..... is stop at Calculating SIMLOCK RPL using security server |
Post screen shot, so we can see full log and the software version. BR, Manole |
» Nokia Service Tool Version from module: 1.0.0.12955 Version from server: 1.0.0.12843 Module version is up to date i try to make update but is up to date |
Hi Mr. wzupfones first go and see in option the servers list ,after press it, i think you will find it empty, just uninstall ur mxkey then delete the folder mobileEX , delete any thing related with mobilex manually, then setup it again nd sign application, see now if u can see servers, i faced same prob the procedure above solved it wish u good luck |
