02-15-2010, 21:03 | #1 (permalink) |
Junior Member Join Date: Feb 2008
Member: 696620 Status: Offline Thanks Meter: 0 | Dead n95 Using device: J.A.F, FW ver: 01.B2 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Processing file: RM-159_35.0.002_PR.C0R as MCU [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 70.30 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Supported APE Ids: 24200705 APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 22E85BCFF1B49E89F7C167DCB25408D9771A96C1 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1730010BB78F00581007514DD649967F93558464 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 ExtDEVC: FFFF 0000 - 0000 0000 Flash ID not supported for this loader (RAPIDOv11_algo.fg) Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS is blank/erased. Warning: No RAP Flash Chip Detected SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS is blank/erased. Storing certificate ...OK Partitioning ...OK Total erase size: 110.89 MB CMT NOR area [00080000-007B1641] CMT NOR area [00000000-0005FFFF] CMT NOR area [00880000-00FDFFFF] APE NAND area [00000200-0000AFFF] APE NAND area [0000B800-000AFFFF] APE NAND area [00000000-00000FFF] APE NAND area [0000D800-0000E9FF] APE NAND area [00080000-000BFFFF] APE NAND area [000E0000-0045FFFF] APE NAND area [004C0000-0073FFFF] APE NAND area [00A40000-0633FFFF] erased in 0.063 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00001000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 32.187 s RX Buffer: C7012D0103CD00 RX2 is disable VPP is auto |
02-15-2010, 21:08 | #3 (permalink) |
Member: 696620 Status: Offline Thanks Meter: 0 | RX2 enable VPP auto Using device: J.A.F, FW ver: 01.B2 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Processing file: RM-159_35.0.002_PR.C0R as MCU [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 70.30 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Supported APE Ids: 24200705 APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 22E85BCFF1B49E89F7C167DCB25408D9771A96C1 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1730010BB78F00581007514DD649967F93558464 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 ExtDEVC: FFFF 0000 - 0000 0000 Flash ID not supported for this loader (RAPIDOv11_algo.fg) Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS is blank/erased. Warning: No RAP Flash Chip Detected SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS is blank/erased. Storing certificate ...OK Partitioning ...OK Total erase size: 110.89 MB CMT NOR area [00080000-007B1641] CMT NOR area [00000000-0005FFFF] CMT NOR area [00880000-00FDFFFF] APE NAND area [00000200-0000AFFF] APE NAND area [0000B800-000AFFFF] APE NAND area [00000000-00000FFF] APE NAND area [0000D800-0000E9FF] APE NAND area [00080000-000BFFFF] APE NAND area [000E0000-0045FFFF] APE NAND area [004C0000-0073FFFF] APE NAND area [00A40000-0633FFFF] erased in 0.078 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00001000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 32.281 s RX Buffer: C7012D0103CD00 |
problem with dead n95 flashed as n95-5 | thecult | MT-BOX | 49 | 09-06-2007 13:23 |
Dead N95 - major help please! | peeejayz | Nokia Base Band 5 ( BB-5 ) | 3 | 05-06-2007 14:58 |
Dead N95 | Weasley | Nokia Base Band 5 ( BB-5 ) | 5 | 04-08-2007 05:20 |
