09-03-2009, 20:32 | #4 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | simlock on st is ok only security have error @ mobilecareke SX4 without right pm will not help try this |
The Following User Says Thank You to mohA™ For This Useful Post: |
12-05-2009, 16:44 | #9 (permalink) |
Freak Poster Join Date: Jul 2007 Location: anywhere
Member: 548078 Status: Offline Thanks Meter: 80 | bro, used modified pm and write SX4uth, your problem is solved, because it is security test failed. using mx-key. read this below. http://forum.gsmhosting.com/vbb/showthread.php?t=874487 |
12-05-2009, 19:07 | #11 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
If you can't obtain the sx4 auth your mobile has superdongle problem and this explane the restarting (watch dog) BR Alex | |
The Following User Says Thank You to moulnisky For This Useful Post: |
12-06-2009, 07:08 | #12 (permalink) | |
Freak Poster Join Date: Nov 2009
Member: 1160909 Status: Offline Thanks Meter: 6 | Quote:
PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN i'm sure superdong is ok...i check it use ohert tool. i want to write pm to the phone..but i can't connect the x4... any idea? | |
12-07-2009, 01:56 | #13 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Lot of people has problems with the 7210. I can tell you that if you rebuilt the Superdongle using the "other tool" I think you are not the only one having this problem.. About checking the superdongle if is valid or not, I can tell you for experience the only valid test is the SX4 auth BR Alex |
Nokia 7210c contact service | NIMESHFONOTLY | Nokia Hardware & Hardware Repair | 78 | 08-23-2012 13:31 |
7210c contact service plz hlp | fofolpo | Nokia Base Band 5 ( BB-5 ) | 2 | 04-02-2009 09:41 |
