05-18-2011, 08:13 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Brunei dar
Member: 597784 Status: Offline Thanks Meter: 348 | 8800 sirocco change language, dead during flashing Done with Simple tricks. With the Help of Simple cable trick Problem solve!. Code: MXKEY Serial: [USB Smart Card Reader 0] - C080xxxxx Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0030 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 005690A0:3B8ADA60 ASIC type: 6 UEM Imei: 35228nnnnnnnnnnn Flash Imei: 35228nnnnnnnn RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35228701162674_BACK.rpl" Processing MCU file: rm16511004.200 [TIKU BT2,TIKU ALGORITHM] size: 12.19 MB Supported Ids: 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0030 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 005690A0:173EDA60 Area [00000000-0000FFFF] erased in 0.500 s Area [00010000-00BFFFFF] erased in 1 min 23.406 s Area [00C00000-00D5FFFF] erased in 9.750 s Area [00E00000-00FEFFFF] erased in 13.516 s Flash programming ... Programming completed in 2 min 13.141 s File Processed in 4 min 16.156 s Processing CNT file: rm16511004.20.image_r_se [TIKU BT2,TIKU MON CSM] size: 19.30 MB Supported Ids: 1052, 10C6, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0030 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660 Supported Ids: 1051, 1052, 2051 Mass Memory Storage Device detected. Configuring MM bus ... Formating partition ...OK Opening MM device ... Erasing disks ...OK Flash programming ... Programming completed in 4 min 41.312 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.047 s File Processed in 5 min 6.360 s Processing PPM file: rm16511004.20r [TIKU BT2,TIKU MON CSM] size: 4.23 MB Supported Ids: 1052, 10C6, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0030 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660 Supported Ids: 1051, 1052, 2051 Mass Memory Storage Device detected. Configuring MM bus ... Formating partition ...OK Opening MM device ... Erasing disks ...OK Flash programming ... Programming completed in 1 min 1.453 s File Processed in 1 min 18.391 s Total time for flashing process(boot+erase+write) was 10 min 41.016 s Phone Type: RM-165 (Nokia 8800 Sirocco) SW Version: V 04.20 18-06-07 RM-165 (c) Nokia Imei plain: 352287nnnnnnnnnnnn Imei OTP: 35228nnnnnnnnnnnnn Product Code: 0541206 Cellular System: GSM ASIC ID: 0x2051, type: 6 Ppm Id: R Language Pack: English,Chinese S,Chinese T (China) Imei net: 352287nnnnnnnnn Version: SIMLOCK SERVER VERSION 63 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0100000000000006 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN The sups team |
The Following User Says Thank You to alexander.tech For This Useful Post: |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
