01-22-2010, 06:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 337450 Status: Offline Thanks Meter: 718 | Does MX support flashing for 6730? logs: FBUS Code: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11809, Date: 21-01-2010 Processing file: rm566_023.010_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 88.26 MB RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 15E002038C6003447591FF45FEAF78FB467671FB ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP ExtBUSC: 46CB 60E9 80E9 CA4A 3043 45F1 9CE0 5ED8 ExtDEVC: FFFF 0000 - 0000 0000 Flash ID not supported for this loader (RAPUv11_algo_xsr16.fg) Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 RAP PAPUBKEYS is blank/erased. Storing certificate ...Error Flashing terminated with error(s) in 59.672 s RX Buffer: Code: Library version: 1.0.0.11809, Date: 21-01-2010 Processing file: rm566_023.010_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 88.26 MB Phone must be switched off, put USB cable to the phone. Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 109FF531 RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00000C34 RAP EM1 ID: 00000C30 RAP PUBLIC ID: 15E002038C6003447591FF45FEAF78FB467671FB RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3A40 [ADL] Secondary boot loaded FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: ONENAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7EE22 Nokia USB ROM detached. [ADL] Update Server code loaded [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 109FF531 [ADL] Verifying communication to device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic Nokia USB Flashing Generic ready. RAP PAPUBKEYS is blank/erased. Storing certificate OK. Partitioning.... Partitioning complete Total erase size: 64.00 KB Flash programming ... WriteDevice failed: Device Not Opened Error while programming [00] at 0x000C0000, Result: 0000 Flashing terminated with error(s) in 43.657 s RX Buffer: Nokia USB ROM detached. |
01-22-2010, 06:07 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | if you have a flash file no need select a model just connect to nokia usb rom and select cnt, ppm and image and flash it here is flash file link http://rapidshare.com/files/33191318...v4.00_6730.exe |
01-22-2010, 10:20 | #4 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | Hi, Only Usb flashing possible. I found bug with current release, thanks for your report. I made quick fix for this, please make single module update. Goto Options|Module-> Select "Nokia Service Tool" and make "Update" Quote:
ALIM Last edited by Alim Hape; 01-22-2010 at 10:57. | |
01-22-2010, 13:43 | #6 (permalink) |
Member: 337450 Status: Offline Thanks Meter: 718 | Version from module: 1.0.0.11809 Version from server: 1.0.0.11826 Partial update available. GET: mobileEx.lib Socket error (10060): Connection timed out OK GET: nk.mx Socket error (10060): Connection timed out OK Update completed, please restart application. Get some error, maybe im updated.... |
01-22-2010, 14:53 | #7 (permalink) |
Member: 337450 Status: Offline Thanks Meter: 718 | Thanks to alim, i got it, but not in new version, i downgrade my mxkey in version 3.3 rev 1.0...the old one got it... Logs here: Code: Library version: 1.0.0.11443, Date: 23-11-2009 Processing file: rm566_023.010_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 88.26 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Phone must be switched off, put USB cable to the phone. Waiting for USB device ... Connect a CHARGER or Press phone's POWER button and hold for a second please ! [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 39810E93 RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00000C34 RAP EM1 ID: 00000C30 RAP PUBLIC ID: 15E002038C6003447591FF45FEAF78FB467671FB RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Secondary boot loaded FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: ONENAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7EE22 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Update Server code loaded [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 39810E93 [ADL] Verifying communication to device OK. RAP PAPUBKEYS is blank/erased. Storing certificate OK. Partitioning.... Partitioning complete Total erase size: 64.00 KB Flash programming ... CMT PAPUBKEYS: 397DCE210733C335E84BAD369EC893FCA06D1BC3 (RAP Certificate 210 v1) written. Programming completed in 23.875 s Processing file: rm566_023.010_19.01_China_prd.rofs2.fpsx as PPM [BB5,XSR 1.6] size: 27.50 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Total erase size: 51.00 MB CMT ONENAND area [06D40000-0A03FFFF] erased in 0.219 s Flash programming ... Programming completed in 7.344 s Processing file: rm566_023.010_C01.01_BLACK_prd.rofs3.fpsx as PPM [BB5,XSR 1.6] size: 8.20 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Total erase size: 25.00 MB CMT ONENAND area [0A040000-0B93FFFF] erased in 0.109 s Flash programming ... Programming completed in 2.188 s Processing file: rm566_023.010_U001.000_prd.uda.fpsx as CNT [BB5,XSR 1.6] size: 168.23 KB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Total erase size: 61.00 MB CMT ONENAND area [0B940000-0F63FFFF] erased in 0.266 s Flash programming ... Programming completed in 0.469 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia 6730 classic USB Generic, ID: 362002BC [ADL] Verifying communication to device OK. Flashing completed in 1 min 22.828 s Phone Type: RM-566 (Nokia 6730c) SW Version: V ICPR82_09w39.1 06-10-09 RM-566 (c) Nokia Imei plain: 35421203279yobb Product Code: 0583013 ApeCoreSw: 023.010 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354212032797279 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 1 min 25.828 s |
01-23-2010, 06:01 | #9 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
BR | |
01-23-2010, 06:07 | #10 (permalink) |
Member: 337450 Status: Offline Thanks Meter: 718 | |
Infinity does not support flashing LG KP215 Confirmed | gee4234 | Infinity-Box | 10 | 09-02-2010 08:21 |
does cruiser support flash/debrand w880i? | fuzhiguo8888 | Cruiser Suite | 5 | 04-30-2007 21:37 |
Help Does Twister Support Flashing 1600 | AbdulKadir | Twisterflasher | 1 | 10-20-2005 08:59 |
Does anybody have FLASH for C35i v05 with the Russian language? | Jurik | x1x to x45/x50 | 0 | 09-10-2000 00:53 |
