Old 08-30-2011, 10:59   #1 (permalink)
Futuro's Avatar
Member: 90668
Thanks Meter: 57
Can't flash N96 (ANSWERED)
Hi all,
When I try to do a "BUS CHECK" on a N96 I get:
MXKEY Serial: [FT SCR2000 0] - C0822859
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Connection status: UHCI:HUB:HUB:USB 1.10 (Full-speed)
Driver: UFS2XX, ver: 1.6.6.0 , NTMP ver: 1.6.6.1
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
APE Data :
SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x]
ASIC MODE ID: 00
PUBLIC ID: 8A24589EF2A122544BBDD8053B3888A65C3FCDC9
ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35
ROM ID: 137A9A3B33259D2C
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1800011493710052C4D483BC150221E9C120D5A9
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
eBB5ProtocolType: OLD
Storage0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
CMT PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
TransmissionMode: DDR&TX2
SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00
Supported Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3
loader not responding (0910000000B172)
And if I flash the phone it doesn't start up at the end.
I have a Flash file @Gbluez sent me for a 5800 (ELF2FLASH_CMT_RAPIDO), should I do the same procedure for this phone?
Before, the phone was working fine, it was just a bit slow. Now it turns on, the screen light turns on but no image and after a bit it turns itself off.
Thanks
Old 08-30-2011, 16:10   #2 (permalink)
Futuro's Avatar
Member: 90668
Thanks Meter: 57
Ufff...
Finally, after several attempts it's almost working again.
I did a full flash erase, and reflashed it with skip HW_CFG and it's alive again... sort of!
Now, in some way, I lost the phone's imei :
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Storage0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: FLASH,NAND, asic:APE
Suggested algorithm: N8815 ALG STNFMS
Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78
APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Original Imei: Empty
Original Product code: Empty
NPC_DATA invalid !
SIMLOCK PA identifier:
[0] PA_SL2
Phone type: RM-247 (Nokia N96-1)
SW version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia
Imei plain: 12345610654321-?
Product code: 0543727
Battery voltage: 4563 mV, current: 148 mA
Language Pack:
- not available.
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
Now, with MX-Key, how can I repair this?
I've read the .ask file but I cant find a way to generate a .rpl file to repair this.
Any help?
Thanks in advance
Old 09-02-2011, 06:45   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
sorry for late reply.
so you used that old file i gave you on this phone?
have you made any backup before?
Old 09-02-2011, 13:12   #4 (permalink)
Futuro's Avatar
Member: 90668
Thanks Meter: 57
Hi,
No I didn't use the file, I was affraid it would damage the phone.
And I can't find the phone's backup so... I think I have to buy a RPL.
Thanks for all your help.
Best Regards,
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Nokia Flash Content. Phantom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-01-2000 23:28
Page generated in 0.20314 seconds with 9 queries
