Old 07-01-2010, 14:06   #1 (permalink)
Member: 936370
Thanks Meter: 6
Red face E 63 unlocking problem
When i try this to unlock by rpl it show
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Product: V ICPR71_09w22 29-05-09 RM-437 (c) Nokia
ApeCoreSw: 200.21.012
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5
ROM ID: 4B9B75103E691FF8
Custom loader not available for this ID !
Reading Simlock info ...
Imei net: 352009048636406
Version: SIMLOCK SERVER
Provider: Hutchinson 3G (3), Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2342000000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F
BLOCK 2: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F
BLOCK 3: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F
BLOCK 4: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F
and when i try it by unlock by code it shows
Counter: 0/3, 0/10
Backup already exist.
ERROR: Missing SP BLOCK or PM corrupted !
sir pls help me .... fix this problem
The Following User Says Thank You to Newtech comm. For This Useful Post:
Old 07-01-2010, 14:37   #2 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Counter: 0/3, 0/10
Counter: 0/3, 0/10
IS this model supported for unlocking? its not in the supported model list. First check it if its SL3 or not. if it is SL3, then not possible to unlock ATM. To identify it in nokia module, go to Service->IMEI & security-> Simlock and then press Identify. If its SL or SL2, then we can unlock it but first identify and post here.
Old 07-02-2010, 13:09   #3 (permalink)
Member: 852547
Sonork: 100.1621506
Thanks Meter: 40
ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5 , this hash not supported yet by any tool yet
Old 07-02-2010, 14:49   #4 (permalink)
Member: 457470
Thanks Meter: 159
E63 unlock is possible in mx key try again
Old 07-02-2010, 14:55   #5 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Yes E63 is supported for Unlocking in MXKey but this is new one and used HASH is not supported by any tool at the moment.
Br,
Shadab Ahmad
Old 07-02-2010, 15:01   #6 (permalink)
faurionutz's Avatar
Member: 607365
Sonork: 100.1590583
Thanks Meter: 294
Make backup and try to tick init simlock and make simlock rpl
Old 07-03-2010, 19:14   #7 (permalink)
Member: 741104
I am no expert and tried for days to unlock e63 but no luck
now i found how to make unlock for e63 sure someone has put this infomation somewhere but i did not find it so here is the log.
Imei net: 3568360236*****
Counter: 0/3, 0/10
BLOCK 2: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F
BLOCK 3: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F
Using device: POTATO BOX, FW ver: 01.B4
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Product: V ICPR71_09w47.3 09-02-10 RM-437 (c) Nokia
ApeCoreSw: 410.21.010
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
Calculating NCK using security server ...
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1
[CR2]BB5 remaining credit: 46
#pw+ 743513427991583 +1 #
#pw+ 372968919664232 +2 #
#pw+ 215355234432374 +3 #
#pw+ 694427102349582 +4 #
#pw+ 397039970139276 +5 #
#pw+ 114885441662444 +6 #
#pw+ 808222023175682 +7 #
Sending NCK code ...
Trying NCK lock 7 ... OK: code accepted.
Completed in 36.406 s
Restarting phone ...
Counter: 0/3, 0/10
BLOCK 1: 1=OPEN, DATA=23420F
BLOCK 2: 1=OPEN, DATA=23420F
BLOCK 3: 1=OPEN, DATA=23594F
BLOCK 4: 1=OPEN, DATA=23594F
For the newbes like me who need step by step here are the details.
first start mxkey ver 3.4.(i used jaf box)
press conect to jaf box or potato flasher.
then click next to gold star and select nokia service tool.
click bus check (should show your phone details)
press the service tab.
press the imei & security tab
press simlock
press unlock by code
click backup simlocl rpl
click calc nkn
then wait for it to do all it work you will see it finds 7 codes but just wait it will chose the corect code and will apply it self.
i also unlocked a n95 8gb the same way.
I am new and as i learn i hope to help others A big thank to everyone here.
if this is any help to anyone please press the Thanks button.
Old 08-03-2010, 06:57   #8 (permalink)
unlocker_786's Avatar
Member: 711273
Thanks Meter: 81
hi
e63 notunlock by max key
Counter: 0/3, 0/10
Backup saved to "BB5_35200904500575_SIMLOCK.back"
The Following User Says Thank You to unlocker_786 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
Page generated in 0.20838 seconds with 9 queries
