01-18-2012, 18:48 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: LIKE MOBILE SOFTWARE
Member: 1084993 Status: Offline Sonork: 100.1617420 Thanks Meter: 641 | E5-00 vibrate only (ANSWERED) VIBRATE ONLY I AM FLASH LATEST FIRMWARE BUT LOCAL MODE TEST OK ALL IS WELL BUT ONLY VIBRATE HERE IS LOGO MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0806A32 Using device: HTI, FW ver: 00.50, SN: 00003E42 Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 234002178E9C0344C4A41FAAAE3F8F5632264ADC ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0xD4029 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C Processing MCU file: rm632_081.004_prd.core.fpsx [BB5,XSR 1.6] size: 102.98 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning ...OK Erase size: 227.31 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0E77FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: CCD9F805 [RAP Certificate v1 238] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 46.361 s Processing PPM file: rm632_081.004_47.01_India_prd.rofs2.fpsx [BB5,XSR 1.6] size: 45.10 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Erase size: 71.50 MB CMT FLASH,MuxOneNAND area [08980000-0D0FFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 2 min 8.419 s Processing PPM file: rm632_081.004_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 8.43 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Erase size: 22.50 MB CMT FLASH,MuxOneNAND area [0D100000-0E77FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 23.566 s Processing CNT file: rm632_081.004_U005.000_prd.uda.fpsx [BB5,XSR 1.6] size: 24.19 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Erase size: 265.75 MB CMT FLASH,MuxOneNAND area [0E780000-1F13FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 9.131 s Total time for flashing process(boot+erase+write) was 8 min 41.404 s Phone type: RM-632 (Nokia E5-00) SW version: V ICPR82_11w16.3.4 17-08-11 RM-632 (c) Nokia Imei plain: 35202304574647-2 Product code: 059B055 Battery voltage: 3909 mV, current: 92 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352023045746472 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN HELP THE MASTER |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Only MAX232 ??? | AMIGO | Nokia Hardware & Hardware Repair | 7 | 04-12-2000 09:41 |
only 1800Mhz ?? | dofie | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-17-2000 21:51 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
