Old 05-13-2012, 11:37   #1 (permalink)
Member: 1124250
Thanks Meter: 62
Arrow Nokia x1 dual sim hung done by Mxkey Green
Flash file used
Model: X1-01
Rm- 713
Flash file
GSMPINOY
Pinout
Input
MCU
PPM
Flashing
Done
kahit may error done parin
Logs
Backup already exists(C:\mobileEx\3.5\data\backup\XGOLD_RM-713_FED68F3B8161EC8E_IMEI.back)
MXKEY [FT SCR2000 0], SN: C08327BB
Using device: HTI, FW ver: 00.50, SN: 0000D0DA
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.24
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 00EC 2404 - 23280002 [Samsung K5N2833ATM,128 Mbits]
CFI information:
Flash settings: 0/1, size: 0x01000000
2 Block regions:
255 x 0x00010000 = 0x00FF0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rm713_005.290
Downloading item CODE:hw_b1_rm713_r05.290.fls, num block: 3, size: 5.58 MB
Erasing area 0x00000000-0x00005FFE ...OK
Programming completed in 0.609 s
Erasing area 0x00800000-0x00BEFFFE ...OK
Programming completed in 1 min 13.813 s
Erasing area 0x00C5D000-0x00DFB6FE ...OK
Programming completed in 31.422 s
Error reading checksum!
Processing file: rm713_005.29ij
Downloading item CUST:hw_b1_rm713_005.29ij.fls, num block: 1, size: 4.78 MB
Erasing area 0x00100000-0x005C6F7E ...OK
Programming completed in 1 min 18.906 s
Checksum mismatch: Phone calculated 0x005D, software calculated 0x8D7E
Processing file: rm7130_nai05.29ij
Downloading item CUST:hw_b1_rm7130_nai05.29ij.fls, num block: 1, size: 708.64 KB
Erasing area 0x00E60000-0x00F1057E ...OK
Programming completed in 11.375 s
Checksum mismatch: Phone calculated 0x00F2, software calculated 0x7E52
Total time for flashing process(boot+erase+write) was 5 min 24.469 s
Phone type: RM-713
SW version: V 05.29 10-06-11 RM-713 (c) Nokia
Imei plain: 35789104700344-8
Product code: 059D8Q2
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IJ
Language Pack:
- not available.
Imei net: 35789104700344
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
The Following User Says Thank You to axxes For This Useful Post:
Page generated in 0.17873 seconds with 9 queries
