Old 06-24-2011, 08:51   #1 (permalink)
Member: 631879
Thanks Meter: 29
I need idea about this problem (ANSWERED)
MXKEY Serial: [FT SCR2000 0] - C0809D4A
Driver: NMWCD, ver: 7.1.32.62
Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011)
Invalid File Header
to product support, im new to this problem "INVALID FILE HEADER" mxkey 3.5 v1.0 which i use
im try to flash nokia 5130c using USB its appear that problem invalid file header plss help. .
THANK YOU
Old 06-24-2011, 09:05   #2 (permalink)
Member: 197541
Thanks Meter: 28
you should select corect file flash, try use vpl file
Old 07-02-2011, 03:14   #3 (permalink)
Member: 631879
Thanks Meter: 29
sir tnx for the reply,
this error what is also the problem
Initializing...
DA_LIB_VER_3.3.4.5
It is sensing the pinout fast,please hold on the phone Power key
RXD=5 TXD=4
Connecting...Please hold on the POWER key until the red gauge is going...
Any errors please select another boot and try again.
BB:6223, HardwareVer:8A05, SoftwareVer:8A00
Failed to set Uart_AUTOBAUD_EN, REG=0x80130020
Failed to test CMD, CMD=0x4154
Old 07-02-2011, 06:12   #4 (permalink)
shybet's Avatar
Member: 492380
Thanks Meter: 184
Connect box drectly to computer USB port. Don't use any USB Hub.
Old 07-02-2011, 08:57   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
so which one is your case? you talked about mtk phones or nokia phones?
- install 5130 data package, select firmware from market drop down menu.
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.14697 seconds with 9 queries
