Old 02-09-2010, 08:25   #1 (permalink)
Member: 1228159
e62 phone startup failed.pls help me
pls any one help me i have e62 phone startup failed contect the retailer. here is log
Phone Type: RM-88 (Nokia E62)
SW Version: V 3.06.33.09.13 17-08-07 RM-88 (c) Nokia.
Imei plain: 35974300050986-1
Product Code: 0538175
ApeCoreSw: 3.0633.31.19 17-08-07 RM-88 (c)Nokia
ApeVariant: 3.0633.31.19_v08 17-08-07 RM-88 (c)Nokia
ContentPack: V1.0 Default RM-88
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
"RM-88" folder created.
Imei net: 359743000509861
Version: SIMLOCK SERVER VERSION 62
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
Old 02-09-2010, 08:31   #2 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
bro u need to repair super dongel
becazz
SIMLOCK_TEST passed
The Following User Says Thank You to waqas_ali601200 For This Useful Post:
Old 02-09-2010, 08:56   #3 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
Repair SUPERDONGLE
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 02-09-2010, 09:32   #4 (permalink)
Member: 1228159
thank you SIRJI
MX_KEY is graet tool. No.1 tool today & tommorow
Old 02-09-2010, 12:35   #5 (permalink)
Member: 1228159
need e62 pm.
hello sir i repair sd data succsess fully by mx-key . but now
SECURITY_TEST failed!
now i need e62 pm file .
thanks in advance
Old 02-09-2010, 12:44   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
1.[MXKEY - INFO] !!! NEW magic button inside mxkey !!!
2.Just in case if Recovery via Server doesn't work.......
3.[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
br,
Old 02-09-2010, 14:21   #7 (permalink)
Member: 1228159
hello sir
i repair sd data & write pm with super sd auth. but still contect retailer.
Product Code: 0537120
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
how to repair block 1 : 1=corrupted
Old 02-09-2010, 14:54   #8 (permalink)
Member: 1228159
hello manole sir
BB5 Certivicate Validation
Service > Phone Test > Various > BB5 Certivicate Validation
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 190001176C49005278291EC22A4A0DD3AAF4E67B
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 22FE - 0000 8D21 [Samsung K8S5615ETA,256 Mbits] type: NOR,RAP
FlashID1: 00EC 0030 - 0000 0011 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: ONENAND,RAP
ALG [35]: BB5 ALGORITHM
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 8665D276B9147EE40DF77CF6781A675E57D46867
Reading RAP NPC (0x168 bytes)
Original Product Code: 0551010
Reading RAP VARIANT (0x4EF bytes)
Product Code missmatch !
Reading RAP CCC (0x0 bytes)
Reading RAP HWC (0x0 bytes)
e62 phone startup failed contect the retailer rafik2533 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-02-2010 08:28
n91 phone startup failed >> help me!!! sameh_LG Nokia Base Band 5 ( BB-5 ) 4 06-03-2009 19:55
HWK upgradation fail, pls Help me neppra HWK 4 11-28-2008 21:04
e90 phone startup failed plz help amirafar2000 Nokia Hardware & Hardware Repair 3 11-07-2008 17:13
Page generated in 0.21517 seconds with 10 queries
