Old 03-19-2010, 09:15   #1 (permalink)
nofear197979's Avatar
Member: 68311
Thanks Meter: 34
x3 flashing done
Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010)
Processing file: rm540__04.11.mcusw as MCU
[BB5,XSR 1.6] size: 25.92 MB
Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1CF43AEA
RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x]
RAP EM0 ID: 00001040
RAP EM1 ID: 00001030
RAP PUBLIC ID: 110003157A440E49A97BF1EB31425EC1EF5C8DC2
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
RAP ROM ID: 67E82268F29CEA60
[ADL] Loading CMT secondary boot code
SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0
Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
[ADL] Secondary boot loaded.
FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP
FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP
[ADL] Loading CMT Update Server Data
Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232
[ADL] Update Server code loaded.
[ADL] Verifying communication to device OK.
RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E
Storing certificate OK.
Partitioning....
Partitioning complete
Erase size: 37.69 MB
Flash programming ...
CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500626C6F (RAP Certificate 193 v.1) written.
Programming completed in 31.828 s
Processing file: rm540__04.11.ppm_meaa as PPM
[BB5,XSR 1.6] size: 6.14 MB
Erase size: 8.87 MB
Programming completed in 7.406 s
Processing file: rm540__04.11.image_meaa_0584327_001 as CNT
[BB5,XSR 1.6] size: 12.58 MB
Erase size: 75.06 MB
Programming completed in 15.515 s
[ADL] Device found: nmwcdc\Nokia X3 USB Generic, ID: 2AC92BC3
Flashing completed in 1 min 43.078 s
Phone Type: RM-540 (Nokia X3-00)
SW Version: V 04.11 09-12-09 RM-540 (c) Nokia
Imei plain: 35936703686515-2
Product Code: 0583926
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359367036865152
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 1 min 46.562 s
thx mxkey............
Old 03-19-2010, 09:21   #2 (permalink)
Member: 1246529
Thanks Meter: 36
n0w with mxkey evryting is p0sible..................
The Following User Says Thank You to sirosoft For This Useful Post:
Old 03-19-2010, 10:02   #3 (permalink)
Member: 534062
Sir what version of USB driver did you used? Can you please upload it here?..
NEW SECURITY (RESPIN) W200 flash Done !! mbiborna SETool2 0 03-29-2010 13:54
nokia X3 flashing problem suffa MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 12-10-2009 19:19
O2 X3 Flashing Problem zubairok Infinity-Box 5 08-27-2007 17:35
Need O2 X3 Flash Files Urgent rajan nishchal Redbox 0 08-30-2006 09:12
Page generated in 0.17672 seconds with 9 queries
