e63 simlock data corrupted (ANSWERED) Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.48.0 revision: 2.0 size: 0x8B45D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Original Imei: 35xxxxxxx Original Product code: 0592129 Bluetooth ID: D87533CC1C8C SIMLOCK PA identifier: [0] PA_SL2 [1] PA_SL3 Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia ApeCoreSw: 510.21.010 Imei plain: 352xxxxxxx Product code: 0592129 Battery voltage: 4833 mV, current: 60 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! urgent plz team waiting for solution |
bro. your phone is sl2 & can be done, go to simlock>repair simlock>update simlock then full factory reset, will solve the problem, have a nice day. |
not done to me ihave try this solution |
bro. then restore backup RPL & again try the above method will solve, i think so..... |
bro did you read this.. Quote:
waiting for master reply |
waiting for nothing....simple sulotion just buy rpl for your fone.. |
i am not sure is this sl3 handset |
New security RAPIDO. Damaged simlock will need original backup in good condition or buy factory rpl. |
Same Problem some one know Who to repair this problem Phone type: RM-449 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-449 (c) Nokia ApeCoreSw: 510.21.010 Imei plain: 35683802475695-2 Product code: 0582494 Battery voltage: 3781 mV, current: 47 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
Please post full buscheck logs to know it further. |
SIMLOCK invalid! SIMLOCK_DATA corrupted! MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0854874 Using device: HTI, FW ver: 00.50, SN: 00002F4F Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1E700001F29E00528C772B2C56494F5FC5BE2655 ASIC MODE ID: 00 ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.50.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.50.0 revision: 2.0 size: 0x8B45D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Original Imei: 35339704926917 Original Product code: 0592129 Bluetooth ID: E0A6702DF531 SIMLOCK PA identifier: [0] PA_SL2 [1] PA_SL3 Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia Imei plain: 35339704926917-1 Product code: 0568890 Battery voltage: 4878 mV, current: 48 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
E63 is sim card not valid BUS CHECK report : MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0854874 Using device: HTI, FW ver: 00.50, SN: 00002F4F Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1E700001F29E00528C772B2C56494F5FC5BE2655 ASIC MODE ID: 00 ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.50.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.50.0 revision: 2.0 size: 0x8B45D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Original Imei: 35339704926917 Original Product code: 0592129 Bluetooth ID: E0A6702DF531 SIMLOCK PA identifier: [0] PA_SL2 [1] PA_SL3 Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia Imei plain: 35339704926917-1 Product code: 0568890 Battery voltage: 4878 mV, current: 48 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Simlock/unlock by code Report: SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Backup already exist. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0854874 Using device: HTI, FW ver: 00.50, SN: 00002F4F Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia ApeCoreSw: 510.21.010 Using cached productData. PUBLIC ID: 1E700001F29E00528C772B2C56494F5FC5BE2655 PRIVATE ID: 9CDA8A05F3D34211A7BEF5545DF7950010DD3345 #pw+ 228989176665992 +1 # #pw+ 245495915041360 +2 # #pw+ 613444246987718 +3 # #pw+ 011592630632757 +4 # #pw+ 775605730295371 +5 # #pw+ 750149392366998 +6 # #pw+ 989059933218887 +7 # Sending NCK code ... Trying mode: FBUS, NCK lock 7(ALL) ...FAILED: not ready Trying mode: FBUS, NCK lock 6(MCCMNC+GID1+GID2) ...FAILED: not ready Trying mode: FBUS, NCK lock 5(MCCMNC+GID1) ...FAILED: not ready Trying mode: FBUS, NCK lock 4(IMSI) ...FAILED: not ready Trying mode: FBUS, NCK lock 3(GID2) ...FAILED: not ready Trying mode: FBUS, NCK lock 2(GID1) ...FAILED: not ready Trying mode: FBUS, NCK lock 1(MCCMNC) ...FAILED: not ready Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! pls help solution thanks................:p:p:p:p:p |
BR, |
