Old 02-10-2010, 14:21   #1 (permalink)
Member: 191786
E66 security test fail
I try manole solution but didn t work, is not supported for repair? here is the log
Phone Type: RM-345 (Nokia E66)
SW Version: V ICPR71_09w22.10 22-10-09 RM-345 (c) Nokia
Imei plain: 35294402014763-6
Product Code: 0564815
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 352944020147636
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following User Says Thank You to radu_m For This Useful Post:
Old 02-25-2010, 15:19   #2 (permalink)
scutarus's Avatar
Member: 80036
Thanks Meter: 25
me too here
something new in this time?
thanks
Old 02-25-2010, 17:07   #3 (permalink)
scutarus's Avatar
Member: 80036
Thanks Meter: 25
i do all the steps allways security_test failed
need some help here thanks
Old 02-25-2010, 17:16   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
with
"SUPER SD auth"
and write PM [1] and [309] area
if not help ,try read carefully this thread
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
what is your problem?
can you post the log for this phone ?
br,
Old 02-25-2010, 18:03   #5 (permalink)
scutarus's Avatar
Member: 80036
Thanks Meter: 25
thank u 4 ur atention
here is my log
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0BB000161DB40158F6FB8D9E94949BD5A2A439EE
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93
Original Imei: 352942023xxxxx
Original Product code: 0566775
Phone Type: RM-343 (Nokia E66)
SW Version: V ICPR71_09w04 20-01-09 RM-343 (c) Nokia
Imei plain: 352942023xxxxx-2
Product Code: 0557965
ApeCoreSw: 210.21.007
ApeVariant: 210.21.007, ApeTest: RM343ENO74110842.a24
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 352942023xxxxxx
Counter: 0/3, 0/10
Old 02-25-2010, 18:46   #6 (permalink)
scutarus's Avatar
Member: 80036
Thanks Meter: 25
btw now when i try to repair simlock it showing
Access violation at adress 02759B62. Read of adress 0660A53C.
and the programm stop and freeze
what it means?
thanks
Imei net: 35294202315xxxx
Counter: 0/3, 0/10
Backup already exist.
Using device: J.A.F, FW ver: 01.B2
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Product:
Sending SecondaryBoot [rapidov11_2nd.fg](0x3AC0 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x11C4 bytes) ...OK
Sending SecurityBlock(0x2000 bytes) ...OK
Sending SimlockBinary(0x190 bytes) ...OK
Sending KEYS [SL20] (0x1A20 bytes) ...OK
Calculating LOCK data ...OK
Unlocked PM saved to "C:\mobileEx\3.3\data\backup\35294202315xxxx_UNLOC KED.PM"
Writing Unlocked PM ... OK
Completed in 23.343 s
Restarting phone ...
Old 02-25-2010, 19:11   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
my instruction order you to make SIMLOCK repair ??
please follow this post carefully .
http://forum.gsmhosting.com/vbb/show...73&postcount=4
br,
Old 02-25-2010, 19:19   #8 (permalink)
scutarus's Avatar
Member: 80036
Thanks Meter: 25
i do like u said
but nothing
same problem
pm than super sd than write pm1 pm309 fields
after this same security test failed
i try to downgrade from 400 to 200 version but is same
please advice
where is my mistake?
thanks
could it be my pm is not good?
did u have a good rm343 pm here
only 1 and 309 fields?
thanks again
Old 02-25-2010, 19:22   #9 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
so you need this
if these steps still not fix the phone, please do BB5 Cert Validation
    Usefull to identify SECURITY_TEST problem specially if SUPERDONGLE is valid
    Button located to [Phone Test->Various]
and follow this thread instruction
br,
Old 02-25-2010, 20:01   #10 (permalink)
scutarus's Avatar
Member: 80036
Thanks Meter: 25
Reading RAP NPC (0x190 bytes)
Original Product Code: 0566775
Reading RAP VARIANT (0x0 bytes)
Reading RAP CCC (0x160 bytes)
Product Code: 0569307
Product Code missmatch !
Reading RAP HWC (0xD4 bytes)
ok how to fix this?
please be patient i'm new with mxkey
thanks for ur help here
Old 02-26-2010, 01:44   #11 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
ok how to fix this?
np,
just want help with some clue
with easy step. "one shot,one kill"
after get this ,
do Super SD auth and write PM
like this post
br,
Old 02-26-2010, 14:24   #12 (permalink)
scutarus's Avatar
Member: 80036
Thanks Meter: 25
Originally Posted by MobileEx-Team View Post
np,
after get this ,
like this post
br,
i do this
many times
but nothing changed
download 3 pm files of this phone
but nothing
something else to test?
can be my pm's are not good?
what can be?
Old 02-26-2010, 14:36   #13 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
it can be.
just try looking normal phone in same type arround of you.
then read PM file
open as notepad and delete [308] and [120] area.
do Super SD Auth and write PM edited.
br,
Old 02-26-2010, 14:55   #14 (permalink)
scutarus's Avatar
Member: 80036
Thanks Meter: 25
i do like this
but same
something is wrong in what i do or this type cannot be done
Old 02-26-2010, 15:17   #15 (permalink)
nadim_mobiles's Avatar
Member: 867259
Sonork: 100.1595961
Thanks Meter: 215
if Sd is Repaired then Agin repair Sd ANd Write FULL pm With super s4x
my problem solved this way
N73 security test fail start up fail mobile_mania MXKEY Nokia Flasher and Unlocker (by Alim Hape) 31 03-14-2013 19:33
succes full repair phone startup failed and security test failed jagdish puri MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-12-2010 14:17
Success two security TEST failed but faile in one 5220 FAILE khokonhajigonj MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-09-2010 15:38
3110C security test fail after sd repair now tested ok GSMaxx MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-06-2010 11:19
Please HELP security test -Failed rakishi Universalbox 0 01-18-2007 23:45
Page generated in 0.26968 seconds with 10 queries
