02-26-2010, 18:19 | #21 (permalink) |
No Life Poster Join Date: Aug 2004 Location: ISLAND Age: 54
Member: 80036 Status: Offline Thanks Meter: 25 | i use this nothing i try yesterday but same allways this security_test failed thanks anyway right now a friend come with 2 pcs locked i'll try to read all from one of this and write into this contact retailer one if i solve i let u know here |
02-26-2010, 18:24 | #22 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 34
Member: 869809 Status: Offline Thanks Meter: 1,751 | will... i have it but in bin format that's mean u can't write it with mx-key but u can write it with saras box(hwk box) if u want it from this link http://www.zshare.net/download/730637230ee49d34/ b.r. |
02-26-2010, 18:48 | #23 (permalink) |
Member: 80036 Status: Offline Thanks Meter: 25 | thanks anyway i'll try first to do with a phone backup but maybe is something wrong with this phone model and i'll be useless i leave a feedback here |
02-26-2010, 20:41 | #24 (permalink) |
Member: 80036 Status: Offline Thanks Meter: 25 | Access violation at adress 02759B62. Read of adress 0660A53C. i try to unlock an e66 and it is out this please what it means this? i just kill an e66 it was a working one i restore the rpl backup and i unlock it with the free solution now the phone is ok but this error is same i want to know what it means "Access violation at adress 02759B62. Read of adress 0660A53C" thanks |
02-26-2010, 23:26 | #25 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | read this distinguish when using NCK and SIMLOCK Repair please take a litle time to read our sticky post [MXKEY - TIPS] MXKEY in practice - What you should know about mobileEx - br, |
02-27-2010, 10:35 | #26 (permalink) |
Member: 80036 Status: Offline Thanks Meter: 25 | ok thank u for ur help here but right now i cannot do repai sd anymore i try to reinstall th mx and now the sw freeze and nothing more no error but freeze and nothing btw what is the meaning of that error? can be something conected with the fact about my antivurus find a local.exe corupted? thanks |
02-27-2010, 12:03 | #27 (permalink) |
Member: 80036 Status: Offline Thanks Meter: 25 | ok i can write here i make full pm from a working one i write in this contact service one i do simlock repair than sd repair than sd auth and write 1 and 309 field same security test failed do it 20 times and same with more than 5 pm's file but this last one i write it is surely a good one try evan to write the rpl without npc data from mxkey but same let me know if i can do something here more if not i trash it away this phone and next time i donnot do anymore this sd repair after all this tests i'm sure if u don't have the full rpl backup u cannot repair nothing if a spoiled phone am i right here or not please some feedback here thanks |
02-27-2010, 18:35 | #28 (permalink) | ||
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
that some like software protection,not a virus Quote:
if want to learn , please do it all step and trick already post on sticky post. just need read carefully and practise by self in first time all is so hard, but if already know all tricks you will be know where the actuall problem br, | ||
02-28-2010, 10:39 | #29 (permalink) | |
Member: 80036 Status: Offline Thanks Meter: 25 | Solution? Jaf Box FW downgrade! Quote:
after 2 days losed here i'm able to give an advice to all like me u know what is the trick? but not really a trick i just flash the jaf box to another firmware and magically the phone is repaired now BUT THIS IS NOT A TRICK i'm sorry but is not my fault in this it is a stupid war and i am, like many others here, between the sides in this war now i know if i want to use jaf i put last fw if i want to use mx i must do a downgrade neither the patched firmware doesn't help is not good for jaf is not good for mx too at least in my case but i tell u if i don't receved an 1680 to unlock it, i don't solve this mistery cause i cannot do it with mx it shows error than i pass to jaf and i fix it, oboviusly after jaf box firmware upgrade after this i pass to mx and with this fw i cannot boot the phone e66 i do firmware jaf box downgrade, i redo all the steps and magically the phone now is repaired THIS, in my opinion, was better to know it from u guys here it is not MY FAULT thanks anyway for ur time | |
N73 security test fail start up fail | mobile_mania | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 31 | 03-14-2013 19:33 |
succes full repair phone startup failed and security test failed | jagdish puri | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-12-2010 14:17 |
Success two security TEST failed but faile in one 5220 FAILE | khokonhajigonj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-09-2010 15:38 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
Please HELP security test -Failed | rakishi | Universalbox | 0 | 01-18-2007 23:45 |
