Old 11-01-2009, 04:04   #1 (permalink)
Member: 503664
Thanks Meter: 61
e71 contact retailer
Phone Type: RM-346 (Nokia E71)
SW Version: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia
Imei plain: 35605903187981-6
Product Code: 0559571
ApeCoreSw: 300.21.012
VariantId: 300.21.012300.21.012_v305_20.05
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei: 356059031879816
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 8000000000000000
BLOCK 1: 1=OPEN, DATA=00101F
help pls
Old 11-01-2009, 07:41   #2 (permalink)
alwi7666's Avatar
Member: 368730
Thanks Meter: 180
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
help pls
Try to write PM with PMM Auth sir...
The Following User Says Thank You to alwi7666 For This Useful Post:
Old 11-01-2009, 07:52   #3 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,950
Use this pm
HERE IS URE PM FILE
WBR
sahil2000ind
Old 11-01-2009, 14:51   #4 (permalink)
Member: 503664
Thanks Meter: 61
i'll try it all last night
but still same...
Old 11-01-2009, 15:14   #5 (permalink)
hacell's Avatar
Member: 1150088
Sonork: ============
Thanks Meter: 254
but still same...
Is still same can you request RPL by server because your simlock corrupt
Old 11-01-2009, 15:21   #6 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@ johnnyml
Try with this PM, you must write it USING SX4 AUTH
http://rapidshare.com/files/30092824..._1_309.pm.html
Old 11-01-2009, 15:39   #7 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
try buy rpl file it will be ok 100%\
Old 11-01-2009, 17:11   #8 (permalink)
Member: 503664
Thanks Meter: 61
rpl is calculated too...
Old 11-01-2009, 17:45   #9 (permalink)
Member: 503664
Thanks Meter: 61
Originally Posted by ptt View Post
@ johnnyml
still same
this is ....
Old 11-02-2009, 12:31   #10 (permalink)
Member: 898887
Sonork: ramazoti
Thanks Meter: 210
still same
this is ....
no, yesterday i repair 7210c has the sam problem(security failed)
please sx4 +pm1&309
after check and post log here
E71 start up failed contact retail globalteck Cyclonebox 3 02-24-2010 22:29
e71 contact retailer adaki_vishal HWK 2 12-20-2009 10:29
Successfull flash av E71 but contact retailer mortezashirazi Universalbox 2 04-29-2009 19:23
E71 contact retailer after flash jason-m Universalbox 4 02-26-2009 20:28
e71 contact retailer jammy99 J.A.F. Plus 1 02-07-2009 21:53
Page generated in 0.17517 seconds with 10 queries
