Old 12-11-2009, 10:44   #1 (permalink)
Member: 52362
Thanks Meter: 35
NEW E72 RM-530 flashed successfully through DEAD USB on MXKEY..
here is the log : >>>>>>
Library version: 1.0.0.11446, Date: 25-11-2009
Processing file: rm530_021.025_prd.core.fpsx as MCU
[BB5,XSR 1.6] size: 96.00 MB
Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104
Phone must be switched off, put USB cable to the phone.
Waiting for USB device ...
Connect a CHARGER or Press phone's POWER button and hold for a second please !
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2A3EB9EB
RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1]
RAP EM0 ID: 00001040
RAP EM1 ID: 00001030
RAP PUBLIC ID: 0B90010A2C660344EFA1E41F49B156E536FD4754
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
RAP ROM ID: 3E273BF637BE26FA
[ADL] Loading CMT secondary boot code
SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3A40
Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
[ADL] Secondary boot loaded
FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP
FlashID2: 00EC 0058 - 0000 0121 [Samsung ] type: ONENAND,RAP
[ADL] Loading CMT Update Server Data
Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7EE22
[ADL] Update Server code loaded
[ADL] Verifying communication to device OK.
RAP PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E
Storing certificate OK.
Partitioning....
Partitioning complete
Total erase size: 64.00 KB
Flash programming ...
CMT PAPUBKEYS: 660D81A4455F6F7F9B81D5D10F5336B14B50635E (RAP Certificate 175 v.1) written.
Programming completed in 26.547 s
Processing file: rm530_021.025_40.01_APAC_QW1_prd.rofs2.fpsx as PPM
[BB5,XSR 1.6] size: 59.20 MB
Total erase size: 71.50 MB
CMT ONENAND area [08980000-0D0FFFFF] erased in 0.375 s
Programming completed in 16.313 s
Processing file: rm530_021.025_C00.01_DEFAULT_prd.rofs3.fpsx as PPM
[BB5,XSR 1.6] size: 7.55 MB
Total erase size: 22.50 MB
CMT ONENAND area [0D100000-0E77FFFF] erased in 0.125 s
Programming completed in 2.125 s
Processing file: rm530_021.025_U000.000_prd.uda.fpsx as CNT
[BB5,XSR 1.6] size: 5.04 MB
Total erase size: 265.75 MB
CMT ONENAND area [0E780000-1F13FFFF] erased in 1.406 s
Programming completed in 3.297 s
[ADL] Device found: nmwcdc\Nokia USB Generic, ID: 30B5D875
Flashing completed in 1 min 37.110 s
Phone Type: RM-530 (Nokia E72-1)
SW Version: V ICPR82_09w36.6 15-10-09 RM-530 (c) Nokia
Imei plain: 35523903083421-7
Product Code: 0587266
ApeCoreSw: 021.025
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355239030834217
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 1 min 40.125 s
Nokia USB ROM detached.
The Following 3 Users Say Thank You to GSM_STARCOM For This Useful Post:
Old 12-11-2009, 11:00   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
which OS(windows) , you are using?
windows xp , or windows vista?
Old 12-11-2009, 11:03   #3 (permalink)
Member: 52362
Thanks Meter: 35
window XP SP3 ...........
Old 12-11-2009, 11:11   #4 (permalink)
armanhosting's Avatar
Member: 410890
Thanks Meter: 88
good test report by using mxkey software..
this will serve as reference for all newbie like me....
br
arman23
Old 12-12-2009, 09:47   #5 (permalink)
Member: 550551
Thanks Meter: 25
sir you have pin out cable for e72 ....where can i donwload the set up of mxkey ...will you please give the link
Old 12-12-2009, 10:00   #6 (permalink)
Member: 48933
Thanks Meter: 104
use E52 cable
wbr,A
Old 12-12-2009, 10:01   #7 (permalink)
smartecs's Avatar
Member: 42370
Thanks Meter: 32
but i try new x-3 can't flash....any success???
NEW 5230 RM-588 flashed successfully through DEAD USB on MXKEY.. (ANSWERED) GSM_STARCOM MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 04-04-2011 05:17
E52 flashed successfully through DEAD USB on MXKEY... GSM_STARCOM MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 03-21-2011 06:33
NEW N97 mini RM-555 flashed successfully through DEAD USB on MXKEY.. GSM_STARCOM MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 12-15-2009 06:43
5730S RM-465 flashed successfully through DEAD USB on latest UB version >>>>> GSM_STARCOM Universalbox 4 09-04-2009 07:27
N97 RM-505 flashed successfully through DEAD USB on latest UB version >>>>> GSM_STARCOM Universalbox 3 07-30-2009 23:20
Page generated in 0.19102 seconds with 9 queries
