e72 flashing error please help for this error the phone was only powering but only vibrate and no display please help attach is the logs in flashing:confused::confused: i also reheat the rapuyama but still same problem fbus logs Version from phone: 023.002 Version from file: 023.002 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35523903670666_BA CK.rpl). RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1A700013E06C03447F7AE5DDFFFD1100E1A4B808 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E TransmissionMode: DDR&TX2 No RAP Flash Chip Detected Processing file: rm530_023.002_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 96.45 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 227.31 MB CMT MuxOneNAND area [00020000-0003FFFF] CMT MuxOneNAND area [00060000-004DFFFF] CMT MuxOneNAND area [008E0000-0E77FFFF] Formating Partition ... erased in 1.234 s Flash programming ... CMT PAPUBKEYS: 660D81A4455F6F7F9B81D5D10F5336B14B50635E (RAP Certificate 175 v.1) written. Error while programming [00] at 0x05D80400, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 7 min 44.641 s RX Buffer: B372 usb logs Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm530_023.002_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 96.45 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: CFD9B27 RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 1A700013E06C03447F7AE5DDFFFD1100E1A4B808 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.48.0 revision: 3.0 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 ERROR: Secondary boot not responding ! Flashing terminated with error(s) in 3.297 s RX Buffer: 37786200 |
try change your "Flash Loader" folder to 9.x.x.xxx in config menu then retry your operation br, |
BR, curvenger. |
I have this problem with new E72 too and I used 09.50.25.2 loader but got error and here is flashing log with MX-KEY Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm530_031.023_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 100.24 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 2A100204F58703443245B04362C375EEF3410E75 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E TransmissionMode: DDR&TX2 No RAP Flash Chip Detected Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 227.31 MB CMT MuxOneNAND area [00020000-0003FFFF] CMT MuxOneNAND area [00060000-004DFFFF] CMT MuxOneNAND area [008E0000-0E77FFFF] Formating Partition ... erased in 1.203 s Flash programming ... CMT PAPUBKEYS: 660D81A4455F6F7F9B81D5D10F5336B14B50635E (RAP Certificate 175 v.1) written. Error while programming [00] at 0x05CC0400, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 7 min 43.219 s RX Buffer: B372 :(:(:(:(:( How/where can i get newer flash loader. Thanks for any help. |
