Old 04-03-2010, 15:12   #1 (permalink)
Member: 127767
Sonork: 100.1646527
Thanks Meter: 6
E72 turn of after 2 minute
Phone Type: RM-529 (Nokia E72-2)
SW Version: V ICPR82_09w46.5 22-01-10 RM-529 (c) Nokia
Imei plain: 35603003xxxxxxx
Product Code: 05867xx
ApeCoreSw: 023.002
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2010-01-12T10:34:29Z
SW Version: 022.007
Variant Version: 006
ProductProfile:
Simlock: open_simlock.bin
Imei net: 35603003xxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
any bady help me
Old 04-03-2010, 17:53   #2 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
ApeCoreSw: 023.002
Language Pack:
- not available.
SUPERDONGLE_KEY seems to be valid <<== Not SD problem.
SIMLOCK_TEST passed
SW Version: 022.007
ProductProfile:
Counter: 0/3, 0/10
any bady help me
You're saying youre phone restarts after 2 minute in this thread and you're saying again that you're phone restarts after 30 seconds in the other thread. which one i right, I think it restart randomly, you should check hardware, open and clean the board carefully with PCB cleaner, check the battery connector and also the battery itself, sometimes it happen when youre battery connection is loose.
The Following User Says Thank You to curvenger For This Useful Post:
Old 04-22-2010, 11:03   #3 (permalink)
Member: 152665
Sonork: 100.1591630
Thanks Meter: 4
i also having a same problem with my E72 that use around 2-5 minit will auto restart.I change battery,clean board,upgrade latest software.I can use the phone for few hour then problem come back agian.So anyone can help about this....thx..
Old 12-14-2010, 11:07   #4 (permalink)
GSMJordan's Avatar
Member: 92813
Sonork: 100.1619156
Thanks Meter: 150
http://forum.gsmhosting.com/vbb/f299...ution-1162936/
help nokia 5700 turn of after faw minut malek_bh Nokia Base Band 5 ( BB-5 ) 2 03-26-2010 23:15
Plz help n70 turn off after 2 minute LOOK_AT_ME_GOOD Nokia Base Band 5 ( BB-5 ) 2 07-16-2009 16:42
3500c turn off after 2 minutes sunnyarora Nokia Hardware & Hardware Repair 7 02-25-2009 20:21
6131 n73 turn off after 2 minutes ms.4011 Nokia Hardware & Hardware Repair 1 01-22-2009 13:21
Page generated in 0.16045 seconds with 9 queries
