06-18-2010, 03:20 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Saumlaki-Maluku Tenggara Barat
Member: 424104 Status: Offline Thanks Meter: 45 | E90 Please select correct loader version from 'Config' menu ! Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 8CF449F03ACB4A1F35FEF12FE8853D7A174FA76E ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: xxxxxxxxxxx0006400C192101011103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0C90010B1D5A00580F2DA73DA47912B94F2646A1 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: F2C6EBADC86E6189 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40 Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.). Please select correct loader version from 'Config' menu ! BUS CHECK UFS NO NOKIA E90 |
06-18-2010, 04:21 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | try reconfig your flash loader setting to Code: X:\mobileEx\3.4\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\8.30.12.34536 because UFS interface not support for new loader br, |
The Following 3 Users Say Thank You to Andra For This Useful Post: |
11-19-2011, 14:22 | #7 (permalink) |
No Life Poster Join Date: May 2009 Age: 49
Member: 1027729 Status: Offline Thanks Meter: 97 | e90 problem flashing with atf Changing MODE : FLASH VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 662631E6 ID DWORD 1 : BE823AE2 ID DWORD 2 : C8F6C717 ID DWORD 3 : 10114688 ID DWORD 4 : 83925F9D 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1220010B ID DWORD 1 : 77940158 ID DWORD 2 : 16E58403 ID DWORD 3 : 7113412F ID DWORD 4 : 0E81E893 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum 2A SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAPIDOv11_2nd.fg Boot File - Version 01.037.01 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 0035 -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : E0 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :0035 ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 0001 Device ID : 0035 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 01000000 (16 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAPIDOv11_algo.fg Algorithm File - Version 01.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request No PAPUBKeysHash Returned Searching for APE Boot File.. SearchForBootstrap_DCT5... C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\omap2420_m1_2nd.fg Boot File - Version Boot File - Revision 0x (2) eBB5ProtocolType == New TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. SendAPECodeRequest_DCT5 FLS1_NO_ERROR.. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0022 Revision ID : 0000 2 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 20 BB ASIC Index : APE 01 Data : OMAP2420 UNISTORE-II-1.5.1 ALG 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : BC SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\teflon_sam_nand_xsr15 1_m1.fg Algorithm File - Version 01.052.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request No PAPUBKeysHash Returned START READING RPL DATA Reading : NPC (CMT) OK Reading : VARIANT (CMT) VARIANT : Empty Reading : CCC (CMT) OK Reading : HWC (CMT) OK Reading : R&D (CMT) OK Reading : PARTNERC (CMT) PARTNERC : Empty Reading : MDM_KEYS (CMT) MDM_KEYS : Empty Reading : NPC (APE) NPC : Empty Reading : VARIANT (APE) VARIANT : Empty Reading : CCC (APE) CCC : Empty Reading : HWC (APE) HWC : Empty Reading : R&D (APE) R&D : Empty Reading : PARTNERC (APE) PARTNERC : Empty Reading : MDM_KEYS (APE) MDM_KEYS : Empty FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\353659017198249\3536590171982 49_62014.rpl FlashInfo.RestartMode : 2 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RA-6\RA6p_074012.C01 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 17 Entry Point : 0x01D0 Page Format : 128K Maximum Page Size : 0x00004000 Changing MODE : FLASH VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 662631E6 ID DWORD 1 : BE823AE2 ID DWORD 2 : C8F6C717 ID DWORD 3 : 10114688 ID DWORD 4 : 83925F9D 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1220010B ID DWORD 1 : 77940158 ID DWORD 2 : 16E58403 ID DWORD 3 : 7113412F ID DWORD 4 : 0E81E893 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum 2A SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAPIDOv11_2nd.fg Boot File - Version 01.037.01 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 0035 -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : E0 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :0035 ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 0001 Device ID : 0035 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 01000000 (16 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAPIDOv11_algo.fg Algorithm File - Version 01.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request No PAPUBKeysHash Returned Searching for APE Boot File.. SearchForBootstrap_DCT5... C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\omap2420_m1_2nd.fg Boot File - Version Boot File - Revision 0x (2) eBB5ProtocolType == New TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. SendAPECodeRequest_DCT5 FLS1_NO_ERROR.. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0022 Revision ID : 0000 2 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 20 BB ASIC Index : APE 01 Data : OMAP2420 UNISTORE-II-1.5.1 ALG 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : BC SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\teflon_sam_nand_xsr15 1_m1.fg Algorithm File - Version 01.052.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : APE 1 Certificate 2 Name : HWC ASIC Index : APE 1 Certificate 3 Name : CCC ASIC Index : APE 1 Certificate 4 Name : R&D ASIC Index : APE 1 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 01 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 01 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 01 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 01 CF STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000003 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00A40000 Size : 013C0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 01E00000 Size : 05140000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 06F40000 Size : 08B00000 PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000 000200A40000013C0000000000040000000201E00000051400 00000000080000000106F4000008B00000ED PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x7A (122) ERASE Blocks : 0x05 (5) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00001000-0001FFFF 1 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00080000-0009FFFF 2 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 000C0000-0011FFFF 3 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00200000-00FDFFFF 4 ERASE_AREA_BB5 0x12 Block Length : 0x43 (67) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 00000000-000003FF 1 : 00000800-0000AFFF 2 : 0000D800-0000D9FF 3 : 0000E900-000BFFFF 4 : 00000000-0001FFFF 5 : 00080000-0027FFFF 6 : 004C0000-0073FFFF 7 : 00A40000-04DFFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000004 Additional Bad : 00000004 Correctable ECC : 00000000 Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000004 Additional Bad : 00000004 Correctable ECC : 00000000 Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000004 Additional Bad : 00000004 Correctable ECC : 00000000 Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000004 Additional Bad : 00000004 Correctable ECC : 00000000 Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000004 Additional Bad : 00000004 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:07 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : RA6p_074012.C01 Total blocks to write : 17 ================================================ FBUS Cable RX2 PIN Diagnostics ================================================ Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000004 Additional Bad : 00000004 Correctable ECC : 00000000 ================================================ INFO: RX2 PIN is OK ================================================ >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
