05-21-2010, 16:13 | #1 (permalink) |
Major Poster Join Date: Mar 2008
Member: 722826 Status: Offline Thanks Meter: 8 | Easy way repair "scurity test failed" - NO NEED "LOAD FROM FILE" - NO NEED EDIT PM etc |
The Following User Says Thank You to aguz23 For This Useful Post: |
05-22-2010, 12:27 | #2 (permalink) |
Freak Poster Join Date: May 2010 Location: Pakistan Age: 47
Member: 1295798 Status: Offline Sonork: brista786 Thanks Meter: 97 | other way this Phone logs when Scanned in Mx-key: Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.00 06-03-09 RM-240 (c) Nokia Imei plain: 35765901674649-9 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! PROCEDURE TO FOLLOW 1.Repair SD 2.SUPER SD Auth 3.PM Write 4.Repair SIMLOCK Step by Step: 1. Repair SD. Under IMEI & Security tab click IMEI Rebuild and click "Repair SD". Wait until mx-key finishes it's job.. Sample Log: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 10.00 06-03-09 RM-240 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.906 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SD.RPL" Updating SUPERDONGLE_KEY ...OK After repairing SUPERDONGLE_KEY, SECURITY_TEST has been damaged. see status: Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.00 06-03-09 RM-240 (c) Nokia Imei plain: 35765901674649-9 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! proceed to next steps to restore SECURITY_TEST. 2. SUPER SD Auth. Under PM tab click "SUPER SD Auth". Again wait for mx-key to finish.. Sample Log: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 10.00 06-03-09 RM-240 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! After the unit has been authorized, you can now write pm fields 1 and 309.. For my case, i use a complete pm file but chose to skip simlock area. 3. Write good pm file. Still under PM tab..Locate "Load from file" then click it.. a folder will pop-up asking you to choose the pm file you would like to write.. pick the file then click "Open". Wait for mx-key to finish. Sample Log: Completed in 7.828 s Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 40, size 16 bytes written. - Key: 41, size 182 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 36 bytes written. - Key: 44, size 182 bytes written. Section: 2 - Key: 0, size 448 bytes written. Section: 4 - Key: 1, size 48 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. - Key: 28, size 2 bytes written. Section: 8 - Key: 1, size 12 bytes written. - Key: 7, size 8 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 2 bytes written. - Key: 64, size 2 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 1 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 4 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 16 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 2 bytes written. - Key: 74, size 13 bytes written. Section: 31 - Key: 4, size 16 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 66 - Key: 0, size 2050 bytes written. - Key: 1, size 240 bytes written. - Key: 2, size 240 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 240 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 240 bytes written. - Key: 12, size 1 bytes written. - Key: 16, size 4 bytes written. - Key: 18, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 57, size 8 bytes written. - Key: 58, size 8 bytes written. - Key: 59, size 8 bytes written. - Key: 60, size 8 bytes written. - Key: 61, size 8 bytes written. - Key: 75, size 8 bytes written. - Key: 76, size 8 bytes written. - Key: 78, size 6144 bytes written. - Key: 79, size 300 bytes written. - Key: 80, size 60 bytes written. - Key: 91, size 3 bytes written. - Key: 92, size 3 bytes written. - Key: 93, size 3 bytes written. - Key: 94, size 3 bytes written. - Key: 95, size 3 bytes written. - Key: 96, size 3 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 4 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 4 bytes written. - Key: 102, size 4 bytes written. - Key: 103, size 6 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 116, size 120 bytes written. - Key: 118, size 30 bytes written. - Key: 119, size 1 bytes written. - Key: 120, size 8 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 26, size 12 bytes written. - 120 skipped Section: 122 - Key: 0, size 2 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 208 - Key: 1, size 4 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 238 - Key: 1, size 1 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 334 - Key: 0, size 1 bytes written. Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 0, size 1 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 4296 bytes written. Section: 354 - Key: 0, size 3 bytes written. Section: 356 - Key: 0, size 2 bytes written. - Key: 1, size 8 bytes written. Section: 362 - Key: 0, size 1 bytes written. - Key: 1, size 120 bytes written. Completed in 9.594 s after pm write, check the status of the unit.. Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.00 06-03-09 RM-240 (c) Nokia Imei plain: 35765901674649-9 Product Code: 0543754 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SECURITY_TEST has been restored.. Proceed to next step to repair SIMLOCK. 4.Repair SIMLOCK. Under "IMEI & SECURITY" click Simlock locate and click "Repair SIMLOCK" in Options menu. Also click "Make SIMLOCK RPL" then then click "Update SpLock". Wait for mx-key to finish. Sample Log: Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 10.00 06-03-09 RM-240 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.672 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 357659016746499 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF After all procedure's are done, scan the unit again to check it's status.. Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.00 06-03-09 RM-240 (c) Nokia Imei plain: 35765901674649-9 Product Code: 0543754 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357659016746499 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Unit successfully repaired.. thanks to Mx-key team.. |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
only Test | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-29-2000 21:43 |
TRICK 6+7 MAKE IT MORE EASY | AMTX99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 11-06-2000 22:50 |
Has someome tested this software Nokia New Series Tool? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-20-2000 16:39 |
I have that soft if smb need ask for testing.. | Nec | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-01-2000 23:47 |
