Member: 281801
Sonork: 100.1608672 Thanks Meter: 158 | here is the *FLASHING LOG Quote: MXKEY [FT SCR2000 0], SN:
Connection status: EHCI:HUB:USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.65
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
Processing MCU file: rm634_071.003_prd.core.fpsx
[BB5,XSR 1.6] size: 102.95 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 415B6E
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 27E0001029A7034440EE4F17CB659F51660B1308
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35339904201116_CE RT.rpl"
CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 227.31 MB
CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
CMT FLASH,MuxOneNAND area [008E0000-0E77FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: CCD9F805 [RAP Certificate v1 238] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 26.437 s
Processing PPM file: rm634_071.003_58.01_APAC_QW2_x3_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 49.11 MB
Erase size: 71.50 MB
CMT FLASH,MuxOneNAND area [08980000-0D0FFFFF]
CMT SOS+ROFS2 block sent
Programming completed in 12.578 s
Processing PPM file: rm632_071.003_C00.01_DEFAULT_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 8.43 MB
Erase size: 22.50 MB
CMT FLASH,MuxOneNAND area [0D100000-0E77FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 2.328 s
Processing CNT file: rm632_071.003_U005_01.000_prd.uda.fpsx
[BB5,XSR 1.6] size: 20.76 MB
Erase size: 265.75 MB
CMT FLASH,MuxOneNAND area [0E780000-1F13FFFF]
Programming completed in 6.563 s
Total time for flashing process(boot+erase+write) was 1 min 30.781 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia E5-00 USB Phonet, PORT_ID: 25226649
Verifying communication to device OK.
Phone type: RM-634 (Nokia E5-00.2)
SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia
Imei plain: 35339904201116-2
Product code: 059D7X9
Battery voltage: 3763 mV, current: 186 mA
ApeCoreSw: 071.003
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353399042011162
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN | Uppon successful flashing. Phone will not power on
It only VIBRATE SHOULD I ERASE. please teach me how to erase this SIMLOCK30 phone without bricking |
