09-21-2012, 10:47 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 771334 Status: Offline Thanks Meter: 58 | Error Error --------------------------- Access violation at address 7C91AA01 in module 'ntdll.dll'. Read of address 0024BEC0 --------------------------- OK --------------------------- |
09-21-2012, 20:18 | #4 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | ----------- Error --------------------------- Access violation at address 7C91AA01 in module 'ntdll.dll'. Read of address 0024BEC0 --------------------------- OK --------------------------- many posts supporters says not better help without screen shots and complete log but you are not understand why? BR. Arsalan gsm2000 |
09-21-2012, 20:24 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | What do you mean, Screen tell more clear picture about what version he using, Sometimes this type Error occurs in between operations, So i think Screen Shot is must. I hope you clear now BR, ZUBER |
09-27-2012, 17:02 | #7 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Download Fresh Copy of MobileEx, Unistall MobileEx & Delete Folder manually, Run CCleaner or any Registry Tool & restart PC. Install Fresh Copy & add Mxkey to Antivirus Exception list or Exclude from Resident Shield of same, as per your Antivirus options. Now Run application & post reply. BR, ZUBER |
09-29-2012, 10:52 | #10 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | 100% Solution if this: Access Violation at Address errors occurs even after Reinstalling Fresh Setup. If you’ve Downloaded PC Drivers from third party Sites, that could explain why you are getting these Access Violation at Address errors. You can check Install & Running Mxkey Application on another PC will work like charm. Only want to say, Update or Reinstall your PC Drivers with it's Original Driver CD or from Official Site of the same. Post reply. BR, ZUBER |
