03-30-2012, 11:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: VOLCANO TEAM Age: 39
Member: 1175029 Status: Offline Sonork: 100.1597135 Thanks Meter: 401 | ERROR: bootstrap failed! (ANSWERED) ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! hel me br. |
The Following User Says Thank You to om telcom For This Useful Post: |
03-30-2012, 14:12 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. error showing showing on all phones then, check & change USB to box cable, if not then replace box from reseller, if occurs only for this phone then check & change FBUS cable, if not solve then check for hardware may be RETU or TAHVO ic. |
03-30-2012, 14:19 | #3 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Quote:
br. i face same problem when u press scan phone not responding u press bus check/flash ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! show this error just connect ok h-set to hti & press bus check/ flash hti works ok, no error show | |
03-30-2012, 23:46 | #8 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | even with l;atest update same prob!!! is it box hardware fault? bought les that a month ago!!! MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: xxxx Using device: HTI, FW ver: 00.50, SN: 0100xxxxxxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012) ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! Task failed at (0800000A)!!! Last RX buffer: 02 00 00 C0 |
03-31-2012, 09:01 | #9 (permalink) |
Registered User Join Date: Jul 2003 Age: 43
Member: 34599 Status: Offline Thanks Meter: 12 | MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: xxxxxxx Using device: HTI, FW ver: 00.50, SN: 0xxxxx8 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 0 0 0 1 1 0 ERROR: bootstrap failed! same bro,this happen since 3 day ago. and after update to latest software still same . bad box from hti........... |
04-17-2012, 15:36 | #10 (permalink) |
Junior Member Join Date: Oct 2008
Member: 882628 Status: Offline Thanks Meter: 1 | Same problem MXKEY [FT SCR2000 0], SN: Cxxxxxx2 Using device: HTI, FW ver: 00.50, SN: 00005421 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! |
04-17-2012, 17:32 | #11 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | If you are sure phone contact to FBUS pins are good, there is a sticky thread regarding this. http://forum.gsmhosting.com/vbb/f550...fault-1325626/ complete step by step solution. |
07-18-2012, 15:21 | #12 (permalink) |
Major Poster Join Date: Jun 2006
Member: 296525 Status: Offline Thanks Meter: 4 | ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! i have also this problem HTI box |
07-19-2012, 09:35 | #13 (permalink) |
Member: 296525 Status: Offline Thanks Meter: 4 | ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! i have also this problem HTI box http://forum.gsmhosting.com/vbb/f550...25626/index6.h |
Fatal Error: Memory Allocation Error ! | fireballz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 08-03-2001 08:46 |
Bootstrap site UPDATED!!! | Bootstrap | GSM Mobile Links | 0 | 06-11-2001 22:26 |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
