error on conecting 1202,1661 please help any one i have both 1202c fleshing cable but every time eror i m using jaf box and mx key both flesher in error on check hardware(bus check) and some time ok when inset charger but after error when again press same button error......... Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11446, Date: 25-11-2009 Boot error: 4F 4E 00 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. please help |
hi, your f-bus cable is bad. use "easy flash" interface cable. br |
use easy cable and select easy cable as interface |
eagy cabe same prb ????? |
my both cable same problem |
as far as 1202 i don't know but for 1661- already success with both fbus and easy. |
point is on interface. can be cable or box. please check. br, |
hello brother same problem with me some time before and now it showing this eror when geting bus check Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 ASIC ID: 0x2292 [UPPCosto ver: 1.3] Missing flash update definition file ! Sorry, Unable to find bootloader for this AsicID ! plz help me whats problem is this ? Br Ahmad |
