11-12-2012, 15:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: bangladesh, dhaka, munshiganj. Age: 37
Member: 570626 Status: Offline Sonork: 100.1579059 Thanks Meter: 129 | Error flash config request! Using device: HTI, FW ver: 00.50, SN: 0000276F Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 Error flash config request! Processing MCU file: RH51_67PE706420.C2 [WD2 BT2,WD2 ALGORITHM] size: 25.97 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 Error flash config request! flashing terminated ! Task failed at (08000027)!!! Last RX buffer: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF WBR shimul. |
11-12-2012, 16:09 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Tick BT in Skip Section next to Fast Flash near Flash Button on Mxkey Application, Now Flash it will solve it, P.S. Your Phone is WD2 Series with Bluetooth IC Damaged, From next time post Buscheck Logs & status with details of Phone. BR, ZUBER |
