Old 04-24-2010, 16:45   #1 (permalink)
Member: 1202336
Sonork: 100.1609163
Thanks Meter: 29
N93 APE bootloader not responding !
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8069(22-04-2010), 1.0.0.12811(22-04-2010)
Rpl backup already exist (F:\mobileEx\3.3\data\backup\BB5_35187101011934_BA CK.rpl).
Processing file: RM55PE200058.C0 as MCU
[BB5,BB5 ALGORITHM,BB5,OMAP2420 UNISTORE-II-1.2.1 ALG] size: 47.65 MB
Supported RAP Ids: 0103192101003000, 010C192101003000
Supported APE Ids: 24200705, 24200704
APE Data :
SYSTEM ASIC ID: 24200704 [OMAP2420 ver: 2.1.1]
ASIC MODE ID: 00
PUBLIC ID: 16CA53B19BDABBFCCD59F5B48B06513DA4F2160B
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000294
EM1 ID: 00000B21
PUBLIC ID: 24C00010FAAE0054F8323BD1CEBF8D51F32C0A24
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 643B2F33E3E6EEFC2D6F45213419C8E368FCB996
SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
Supported APE Ids: 24200703, 24200704, 24200705, 24200706
Flashing terminated with error(s) in 25.828 s
RX Buffer: F372
Old 04-24-2010, 16:51   #2 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
what phone problem ?
try with ded usb
Old 04-24-2010, 17:49   #3 (permalink)
Member: 1202336
Sonork: 100.1609163
Thanks Meter: 29
change the language and died
Old 04-24-2010, 17:56   #4 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
flash phone with last ver use ded usb will work
Old 07-07-2010, 02:32   #5 (permalink)
lynspyre's Avatar
Member: 786200
Thanks Meter: 19
I got same error with UFS3-Tornado Flasher.. But tried with JAF Flasher Interface (RED Type - Potato Flasher) and problem solved..
Version from phone: 20.0.062
Version from file: 35.0.002
Using device: POTATO BOX, FW ver: 01.B2
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35898501029357_BA CK.rpl).
Processing file: RM-313_35.0.002_PR.C0R as MCU
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 72.16 MB
Supported RAP Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: C04544386B39C817780712785A9D2EC4CE0E45D7
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 08D0010B3DAA00580B0A13409F773088674C29D7
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED
FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248
APE PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED
Storing certificate ...OK
Partitioning ...OK
Erase size: 123.38 MB
CMT NOR area [00080000-007CF13D]
CMT NOR area [00000000-0005FFFF]
CMT NOR area [00880000-00EFFFFF]
APE NAND area [00000200-0000AFFF]
APE NAND area [0000B800-000AFFFF]
APE NAND area [00000000-00000FFF]
APE NAND area [0000D800-0000E9FF]
APE NAND area [00080000-000BFFFF]
APE NAND area [000E0000-0045FFFF]
APE NAND area [004C0000-0073FFFF]
APE NAND area [00A40000-0707FFFF]
erased in 30.469 s
Flash programming ...
CMT PAPUBKEYS: F8311F20A18CAD3B70A4F896C74DD8711E189EED (RAP Certificate 91 v1) written.
APE PAPUBKEYS: F8311F20A18CAD3B70A4F896C74DD8711E189EED (APE Certificate 91 v1) written.
Programming completed in 5 min 5.922 s
Processing file: RM-313_35.0.002_PR.v21 as PPM
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 11.85 MB
Supported RAP Ids: 4003192101021103, 400C192101021103, 4003192101002003, 400C192101002003, 400C192101011103, 4003192101011103, 4003192101031103, 400C192101031103
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Partitioning ...OK
Erase size: 25.12 MB
APE NAND area [05760000-0707FFFF]
erased in 0.141 s
Programming completed in 49.672 s
Processing file: RM313_31.0.016_015_uda_4.fpsx as CNT
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 30.12 MB
Supported RAP Ids: 4003192101021103, 400C192101021103, 4003192101002003, 400C192101002003, 400C192101011103, 400C192101021105, 4003192101021105, 400C192101031103, 4003192101031103
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 136.06 MB
APE SOS-USER
APE NAND area [07080000-0F87FFFF]
erased in 0.078 s
Programming completed in 5 min 20.687 s
Flashing completed in 12 min 18.468 s
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
hope it is not too comercial aleksj Wanted Products 0 06-12-2000 13:22
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-02-2000 22:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
Page generated in 0.20305 seconds with 9 queries
