Old 06-04-2010, 07:18   #1 (permalink)
nageshh's Avatar
Member: 890991
Thanks Meter: 146
Error Flashing Nokia 1110
Hello friends,
I had nokia 1110 hanging some times.
but in flash process there is error such as Content extract failed.
now phone is in dead condition,
here is log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 005258A0:2984DA60
ASIC type: 2
UEM Imei: 35367001445631
Flash Imei: 35367001445631
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35367001445631_BA CK.rpl"
Processing file: rh70_05.530 as MCU
[DCT4,DCT4 ALGORITHM] size: 1.89 MB
Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033
Area [01000000-0100FFFF] erased in 0.515 s
Area [01010000-013BFFFF] erased in 24.547 s
Area [013C0000-013EFFFF] erased in 1.407 s
Area [017C0000-017EFFFF] erased in 0.062 s
Flash programming ...
Programming completed in 14.406 s
File Processed in 52.422 s
Processing file: rh700_nai5.53ea as CNT
[DCT4,DCT4 ALGORITHM] size: 162.27 KB
Area [01380000-013BFFFF] erased in 1.828 s
Programming completed in 1.297 s
Content extract fail, continue anyway ...
File Processed in 36.687 s
Processing file: rh70_05.53ea as PPM
[DCT4,DCT4 ALGORITHM] size: 1.40 MB
Area [011E0000-011EFFFF] erased in 0.500 s
Area [011F0000-0137FFFF] erased in 10.594 s
Programming completed in 10.719 s
File Processed in 34.141 s
Flashing completed in 2 min 39.375 s
Phone not responding !
Total time to process is 3 min 22.922 s
please help.
Old 06-04-2010, 07:45   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
flash with latest ver
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 06-04-2010, 10:18   #3 (permalink)
nageshh's Avatar
Member: 890991
Thanks Meter: 146
tried this solution but no luck
Old 06-04-2010, 10:38   #4 (permalink)
Biocell's Avatar
Member: 597789
Thanks Meter: 147
just close vpp pin as shown by picture... and reflash the phone...
credits go to who originally make this solutions...
The Following User Says Thank You to Biocell For This Useful Post:
Old 06-04-2010, 10:54   #5 (permalink)
nageshh's Avatar
Member: 890991
Thanks Meter: 146
thanks for reply.
but please convert all words in image in english.
Old 06-04-2010, 12:53   #6 (permalink)
nageshh's Avatar
Member: 890991
Thanks Meter: 146
anyone please help.
need urgent help
Old 06-04-2010, 12:57   #7 (permalink)
Member: 462076
Sonork: 100.1586314
Thanks Meter: 307
s
boss can u explain in english
Old 06-05-2010, 11:23   #8 (permalink)
Biocell's Avatar
Member: 597789
Thanks Meter: 147
soory... for late reply...
hope this can help.... just close pin vpp...so we just use 4 pin...not 5 pin as usually...
Old 06-05-2010, 16:10   #9 (permalink)
nageshh's Avatar
Member: 890991
Thanks Meter: 146
tried bro.......
but no luck same error.
please if possible upload latest good flash file
Old 06-07-2010, 06:53   #10 (permalink)
Biocell's Avatar
Member: 597789
Thanks Meter: 147
try using JAF Crack..........
make sure your cable is good...
Old 06-07-2010, 06:57   #11 (permalink)
javedsf's Avatar
Member: 811013
Sonork: 03468717163
Thanks Meter: 744
ues jaf box 100 ok flash
Old 06-07-2010, 07:53   #12 (permalink)
nageshh's Avatar
Member: 890991
Thanks Meter: 146
I flashed handset without cnt file.
now set is going in local mode & test mode also.
after power on it is powering on.
but after inserting battery it is showing Contact service.
I think mow it is pm problem
Old 08-11-2010, 17:29   #13 (permalink)
Member: 1362100
Sonork: 100.1656342:dr.mobile
FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
UEM ID: 00833ACE:2984DA60
ASIC type: 2
UEM Imei: 35896501054086
Flash Imei: 35896501054086
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35896501054086_BA CK.rpl"
Processing file: rh93_05.530 as MCU
Area [01000000-0100FFFF] erased in 0.640 s
Area [01010000-013BFFFF] erased in 38.235 s
Area [013C0000-013EFFFF] erased in 2.125 s
Area [017C0000-017EFFFF] erased in 0.125 s
Area [01FC0000-01FEFFFF] erased in 0.125 s
Programming completed in 19.703 s
File Processed in 1 min 10.953 s
Processing file: rh930_nai5.53aa as CNT
[DCT4,DCT4 ALGORITHM] size: 160.50 KB
Area [01380000-013BFFFF] erased in 2.656 s
Programming completed in 1.734 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.032 s
File Processed in 17.828 s
Processing file: rh93_05.53aa as PPM
[DCT4,DCT4 ALGORITHM] size: 1.39 MB
Area [011E0000-011EFFFF] erased in 0.672 s
Area [011F0000-0137FFFF] erased in 16.078 s
Programming completed in 14.547 s
File Processed in 41.672 s
Flashing completed in 2 min 42.672 s
Phone Type: RH-93
SW Version: V 5.53 20-07-06 RH-93 (c) NMP
Imei plain: 35896501054086-4
Product Code: 0533137
Cellular System: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: AA
Language Pack:
English,Dannish,Norwegian,Swedish
Imei net: 35896501054086
Version:
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 8000000000010002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
i fallow this solution success THANKS BROTHER
Old 04-14-2011, 18:08   #14 (permalink)
Crazy Poster
Member: 895056
Sonork: 25732
Thanks Meter: 7
thanks for help but no luck
Old 04-14-2011, 18:11   #15 (permalink)
Member: 1548974
Sonork: funkytech
try to flash it in ufs without the said content just mcu and ppm..hope cud help u out buddy
Page generated in 0.25148 seconds with 9 queries
