03-25-2010, 11:05 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: MY MAMA LAND
Member: 504913 Status: Offline Sonork: 100.1659651 Thanks Meter: 28 | error in mx-key Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. |
03-25-2010, 11:09 | #2 (permalink) |
Member: 504913 Status: Offline Sonork: 100.1659651 Thanks Meter: 28 | This is the log of the same phone with ufs . Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! |
03-25-2010, 11:49 | #3 (permalink) |
Member: 504913 Status: Offline Sonork: 100.1659651 Thanks Meter: 28 | What is this also in bb5 using mx-key Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Unknown ID ! Error getting boot info ! |
6300simlock repair error (solved) in Mx-key | WAJID PNR | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-17-2010 08:09 |
SD Auth in Mx-key Good news for mx-key user | muksforu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-28-2010 12:02 |
Error install mx-key in win 7 and xp mode | suarezfco | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 01-24-2010 03:33 |
every time error on bb5 model in mx key | prakashmborana | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-16-2010 08:17 |
problem in mx-key error in flash | FEATURE GSM™ | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 07-30-2009 09:23 |
