Error while programming [00] at 0x000582C0, Result: 0000 (ANSWERED) MANOLE SIR. pls help me when i flash any bb5 handset give this error; ----------------------------------------------------------- 5220 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm411__07.23.mcusw as MCU [BB5,BB5 ALGORITHM] size: 19.92 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1350011409695750075336CFA00A53321D1F1271 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.828 s CMT NOR area [000006C0-0001FFFF] erased in 0.157 s CMT NOR area [00040000-000BFFFF] erased in 0.968 s CMT NOR area [000C0000-0013FFFF] erased in 0.219 s CMT NOR area [00140000-0137FFFF] erased in 4.297 s CMT NOR area [01380000-0151FFFF] erased in 0.468 s Flash programming ... Error while programming [00] at 0x000582C0, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 41.453 s RX Buffer: F372 ---------------------------------------------------------- 7210c Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm436__07.23.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.06 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0E6000180FF05850D9A0670E2B9395C839FF5478 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 19.12 MB CMT NOR area [00000000-000006BF] erased in 0.797 s CMT NOR area [000006C0-0001FFFF] erased in 0.140 s CMT NOR area [00040000-000BFFFF] erased in 0.844 s CMT NOR area [000C0000-0013FFFF] erased in 0.219 s CMT NOR area [00140000-0119FFFF] erased in 3.844 s CMT NOR area [011A0000-0133FFFF] erased in 0.468 s Flash programming ... Error while programming [00] at 0x000582C0, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 40.985 s RX Buffer: F372 |
Hello, send it me in private. After you get contacts. BR -------------------------------------------------------------------------------- |
this is a cable problem while all the 5220 rm-411 had no problems in flashing tested by me with Mx-Key!Use another cable |
so you are using ufs interface try using another interface like jaf box interface..... |
hi, if you're sure the phone is good, well, looks like you're using bad cable. check phone connection and pins. or you can try to flash it by using usb cable. but damaged cmt will bring failed on it. BR |
