02-06-2010, 15:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Error while repairing imei by MX KEY this is the log of 1208 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00571B1BA3BDA66 ASIC type: 11 UEM Imei: 353503******** Connecting to server ...OK, Login ... Hello C080066C, you have 760 credits left. Invalid DATA1 length, expected: 80 chars. pls help |
02-12-2010, 18:34 | #11 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | Here check it server ok but fail to repair imei is it version problem or what i can't understand please mxkey them help... ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 009965EA:2984DA60 ASIC type: 2 UEM Imei: 35623204281170 Connecting to server ...OK, Login ... Hello C080A53C, you have 2010 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35623204281170.RP L" ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 009965EA:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RM-4 SW Version: V 8.11 19-06-06 RM-4 (c) NMP 2300 Imei plain: ??????????????-? Product Code: 0514085 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: AD903D2C6D65A3DA PROFILE_BITS: A870C378EBE45782 BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! |
Video Flash & Repair RPL By MX-KEY | Audsky | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 07-03-2010 00:07 |
Video Flash & Repair RPL By MX-KEY BY MANI2050 CHAKWAL PAKISTAN | mani2050 | Nokia Base Band 5 ( BB-5 ) | 13 | 03-07-2010 12:10 |
Video Flash & Repair RPL By MX-KEY | gsm junction | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-28-2010 08:58 |
Who successfully repair SD by MX-Key ?? plz post here... | TheFoXMK | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 02-05-2010 09:17 |
1200 ???????? imei convert to 1208 try to repair imei by mx-key but some error appear | mine4ever | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 01-16-2010 13:36 |
