Flashing RM-504 (5530 XM) Problem With UFS Interface First i Check with Jaf Interface and result is Quote: Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 2090001791810052BEDB1E8526AB2553A4B294F0
ASIC MODE ID: 00
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.38.1 revision: 2.0 size: 0x3B40
Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 New Protocol is not supported for the current interface (POTATO BOX, FW ver: 01.B1). | And I try With UFS interface and same result here Quote: Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.) | but for jaf Interface i can solved with the last box firmware
here result Quote: Using device: POTATO BOX, FW ver: 01.B4
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
TransmissionMode: DDR&TX2
FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP
FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: MuxOneNAND,RAP
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 9.38.1 revision: 2.0 size: 0x70922
RAP PAPUBKEYS HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF
RPL saved to "C:\mobileEx\3.2\data\backup\BB5_35825303034060_BA CK.rpl"
Processing file: RM-504_20.0.080_prd.core.C00 as MCU
[BB5,XSR 1.5] size: 101.85 MB
Supported RAP Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Storing certificate ...OK
Partitioning ...OK
Erase size: 158.19 MB
CMT MuxOneNAND area [00040000-00082FFF]
CMT MuxOneNAND area [00083400-003FFFFF]
CMT MuxOneNAND area [00400000-007FFFFF]
CMT MuxOneNAND area [00800000-00D5FFFF]
CMT MuxOneNAND area [00D60000-09E5FFFF]
Format Partition ...
Flash programming ...
CMT PAPUBKEYS: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF (RAP Certificate 168 v.1) written.
Programming completed in 8 min 18.579 s
Processing file: RM-504_20.0.080_prd.rofs2.V11 as PPM
[BB5,XSR 1.5] size: 19.17 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 34.00 MB
CMT MuxOneNAND area [07160000-0935FFFF]
Programming completed in 1 min 35.782 s
Processing file: RM-504_20.0.080_C01_prd.rofs3.fpsx as PPM
[BB5,XSR 1.5] size: 5.04 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 11.00 MB
CMT MuxOneNAND area [09360000-09E5FFFF]
Programming completed in 25.343 s
Processing file: RM504_20.0.080_006_000_U001.uda.fpsx as CNT
[BB5,XSR 1.5] size: 4.89 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 88.75 MB
CMT MuxOneNAND area [09E60000-0F71FFFF]
Programming completed in 25.344 s
Flashing completed in 12 min 19.843 s
Phone Type: RM-504 (Nokia 5530 XpressMusic)
SW Version: V ICPR72_09w36.5 25-09-09 RM-504 (c) Nokia
Imei plain: 35825303034060-1
Product Code: 0577064
ApeCoreSw: V 20.0.080
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358253030340601
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 12 min 33.531 s | can any one solved that ufs interface problem
br
rie2n |
