04-04-2010, 08:27 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Bangladesh Age: 41
Member: 648647 Status: Offline Sonork: 100.1603328 Thanks Meter: 967 | Flashing terminated my mx key why????? Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\35707100228728_BACK.r pl). Processing file: rh64_07.020 as MCU [DCT4,DCT4 ALGORITHM] size: 1.84 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008BF813:2984DA60 Area [01000000-0100FFFF] erased in 0.516 s Area [01010000-013BFFFF] erased in 28.531 s Area [013C0000-013EFFFF] erased in 1.406 s Area [017C0000-017EFFFF] erased in 0.125 s Area [01FC0000-01FEFFFF] erased in 0.125 s Flash programming ... Programming completed in 16.563 s File Processed in 56.000 s Processing file: rh640_nai7.02ad as CNT [DCT4,DCT4 ALGORITHM] size: 139.08 KB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008BF813:2984DA60 Area [01380000-013BFFFF] erased in 1.921 s Flash programming ... Programming completed in 1.282 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.031 s File Processed in 25.985 s Processing file: rh64_07.02ad as PPM [DCT4,DCT4 ALGORITHM] size: 1.43 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 Boot error: FF FF FF 72 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 1 min 46.578 s RX Buffer: 0000000000F172 Whare is problem ???? now phone is dead,i m trying & trying but same condition after i flash with jaf box now phone is ok.So whare was folt in my mx key........? i cant flash with mx key why ???? Pls help me.... |
The Following User Says Thank You to Shantobhai For This Useful Post: |
04-04-2010, 08:50 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | Quote:
i face this problem many time on mxkey not jaf take care | |
04-04-2010, 11:22 | #8 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
Still N73 Flashing Error in MX-Key | romeoluv56 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 10:33 |
My MX KEY is blocked | hibba | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-03-2010 15:14 |
mx-key...why always error in usb flashing?? | cristi_slob | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-23-2010 05:34 |
why my mx key gone block | qasi786 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-23-2010 06:13 |
Help me pls!!!!!i cant sign my mx key?why | jasimbinrashid | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-05-2010 08:11 |
