Old 12-17-2011, 08:33   #1 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 573
hahahaha DCT4 booting.....
V bad
ASIC ID: 0x2201 [UPP_2M ver: 2]
Error sending bootloader !
Old 12-17-2011, 09:12   #2 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
Originally Posted by Shani3 View Post
V bad
phone should be hardware faulty or bad cable
Old 12-17-2011, 09:15   #3 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 573
bro mobile on . whit ufs is ok
Old 12-17-2011, 09:16   #4 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
just flashed 2 dct4 & 1 dct4 inf xgold, i suggest u do sync files, dct4 bugs fixed available...
good luck bro
br
Old 12-17-2011, 09:36   #5 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
same her
all so try to boot
Old 12-17-2011, 12:15   #6 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
V bad
You still not read rules how to post full log and screen shots ?
Old 12-17-2011, 12:43   #7 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
For me it is working very fine.
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011)
SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C58
Performing Flash Authentication ...OK
UEM ID: 00479AF4:2984DA60
ASIC type: 2
UEM Imei: 35976600721179
Flash Imei: 35976600721179
MasterCode: 5435470062
RPL saved to "C:\mobileEx\3.5\data\backup\35976600721179_132410 2624_BACK.rpl"
Phone type: RH-93
SW version: V 6.40 12-01-07 RH-93 (c) NMP
Imei plain: 35976600721179-3
Product code: 0533137
Cellular system: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: IA
Language Pack:
English,Arabic,Farsi,French,Urdu
Master code: 6022663413
Imei net: 35976600721179
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000010002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=
The Following User Says Thank You to amn32 For This Useful Post:
boot count problem Devils-thoughts Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-06-2001 12:49
8810 & 8210 Phone NOT respond! (Load Boot data) AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-25-2001 14:47
F_loaders.bin and Boot.bin .. . micklong Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-29-2001 14:49
Phone not respond! (Load boot data) Need a help ! SashaM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-23-2001 02:10
Phone dont respond ( boot count ) galles Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-31-2000 01:53
Page generated in 0.19112 seconds with 9 queries
