adnanskyland | 02-21-2010 06:33 | @ Hasnain..... 1 Attachment(s) I have 6125 I did as you said in one post
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SD RPL repair
4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model Quote:
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Product: V 05.43 24-05-07 RM-178 (c) Nokia.
Using cached productData[2FD0010B83250054370155CE21E94BA1E1EFC6EA] ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized :)!
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 1 (4 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 5 (4 bytes)
Warning: failed to write 1 - 6 (86 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (86 bytes)
Warning: failed to write 1 - 15 (4 bytes)
Warning: failed to write 1 - 16 (86 bytes)
Warning: failed to write 1 - 18 (86 bytes)
Warning: failed to write 1 - 20 (86 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 26 (110 bytes)
Warning: failed to write 1 - 27 (4 bytes)
Warning: failed to write 1 - 28 (98 bytes)
Warning: failed to write 1 - 29 (6 bytes)
Warning: failed to write 1 - 31 (86 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Completed in 4.766 s
| But still as below.. Quote:
Phone Type: RM-178 (Nokia 6125)
SW Version: V 05.43 24-05-07 RM-178 (c) Nokia.
Imei plain: 35884400102001-4
Product Code: 0536384
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 358844001020014
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
| Here is Pm and Rpl Read from phone... How to solove...... |
