04-08-2010, 13:14 | #1 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1259594 Status: Offline Thanks Meter: 2 | Hasnain HElp Me Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0576443)... OK Updating PSN (HED533525)... OK Updating HWID (1000)... OK Updating SIMLOCK...error 0x17 Updating SUPERDONGLE_KEY ...OK Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35422303161209-6 Product Code: 0576443 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! Any Solution ????????????????????????????? |
04-08-2010, 14:29 | #4 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | @Bonga_2010 did you write that rpl which mr.hasnian (magic baba) provide you from your logs i know your phone should going ok save all the logs and post result we will waithing for your report |
04-08-2010, 14:54 | #5 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 524163 Status: Offline Sonork: 1589680 Thanks Meter: 33 | Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35934302208470-2 Product Code: 0544343 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359343022084702 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Was easily solved by Magic Man Hasnain Sir, Thanx to him a lot. Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35934302208470-2 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359343022084702 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
04-08-2010, 14:56 | #6 (permalink) |
Member: 524163 Status: Offline Sonork: 1589680 Thanks Meter: 33 | dashingmash: Please Help Sir, 3110c Security Test Failed. dashingmash: tried to do everything, but same problem //--BB5 repair with imei 1234567654321? available...: send me RPL here dashingmash: please help sir //--BB5 repair with imei 1234567654321? available...: where u posted on forum //--BB5 repair with imei 1234567654321? available...: send me link dashingmash: Sir not posted in forum, You have sent 1 file to //--BB5 repair with imei 1234567654321? available.... Copy of BB5_35934302208470_BACK.rpl //--BB5 repair with imei 1234567654321? available...: what u have done yet ?? dashingmash: Sir, 1. Repair SD 2. Write PM with Super SD Auth, not solved then edited RPL wrote it to the phone //--BB5 repair with imei 1234567654321? available...: write this RPL //--BB5 repair with imei 1234567654321? available...: and tell me //--BB5 repair with imei 1234567654321? available...: thanx You have received 1 file from //--BB5 repair with imei 1234567654321? available.... dashing mash _BACK 3110c ok.rpl Open (Alt+Shift+O) dashingmash: sir, after writing this RPL, should i go for Repair SD and PM. //--BB5 repair with imei 1234567654321? available...: press scan and send me log after this RP L dashingmash: Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35934302208470-2 Product Code: 0544343 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359343022084702 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED //--BB5 repair with imei 1234567654321? available...: now all is ok //--BB5 repair with imei 1234567654321? available...: jusr REPAIR SL //--BB5 repair with imei 1234567654321? available...: make simlock RPL ticked //--BB5 repair with imei 1234567654321? available...: after that SD repair //--BB5 repair with imei 1234567654321? available...: than super sx4 than pm dashingmash: Ok sir, I'll do it dashingmash: Thanx A Lot, sir dashingmash: Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35934302208470-2 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359343022084702 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN //--BB5 repair with imei 1234567654321? available...: good dashingmash: Sir, will u please tell me what i'm going wrong. //--BB5 repair with imei 1234567654321? available...: man these are my skills //--BB5 repair with imei 1234567654321? available...: i could edit RPL of SL3 too //--BB5 repair with imei 1234567654321? available...: as u can see on forum dashingmash: U r genius sir, thanx a lot. dashingmash: i appreciate u and ur work, I'm just waiting for 5130c. //--BB5 repair with imei 1234567654321? available...: ok But Again ----- dashingmash: Sir it again shows security test failed dashingmash: Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35934302208470-2 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359343022084702 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN dashingmash: Sir please help dashingmash: sir r u there //--BB5 repair with imei 1234567654321? available...: do SD //--BB5 repair with imei 1234567654321? available...: than Super SX4 //--BB5 repair with imei 1234567654321? available...: than PM dashingmash: yes sir i've done it //--BB5 repair with imei 1234567654321? available...: ok now ? dashingmash: same sir, sc test failed //--BB5 repair with imei 1234567654321? available...: ok //--BB5 repair with imei 1234567654321? available...: download showmypc //--BB5 repair with imei 1234567654321? available...: and send me password dashingmash: 22608-58364446 dashingmash: 22608-58364446 //--BB5 repair with imei 1234567654321? available...: let me send u a pm file //--BB5 repair with imei 1234567654321? available...: may be pm file is not good You have received 1 file from //--BB5 repair with imei 1234567654321? available.... 3110c_RM-237_rpl.pm Open (Alt+Shift+O) dashingmash: let me edit ur RPL ,more You have received 1 file from //--BB5 repair with imei 1234567654321? available.... dash 3110c .rpl Open (Alt+Shift+O) //--BB5 repair with imei 1234567654321? available...: done now //--BB5 repair with imei 1234567654321? available...: enjoy //--BB5 repair with imei 1234567654321? available...: that is what we call magic //--BB5 repair with imei 1234567654321? available...: that's why they call me Magician dashingmash: U r really a Magic Man dashingmash: thanx sir //--BB5 repair with imei 1234567654321? available... has declined your file transfer. dashingmash: thanx thanx thanx //--BB5 repair with imei 1234567654321? available...: http://forum.gsmhosting.com/vbb/f550...1/#post5684149 Last message received on 08/04 at 7:16 PMBookmark |
04-08-2010, 15:30 | #9 (permalink) |
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | [QUOTE=Bonga_2010;5684499]Not Work for me but thx for helping Hasnain[/Q OK THEN SHOW YOUR LOGS HERE WANT TO CHECK WHAT IS THE ERROR |
04-08-2010, 15:37 | #10 (permalink) | |
Member: 1259594 Status: Offline Thanks Meter: 2 | [QUOTE=rakesh15;5684510] Quote:
Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 128001036C1F7E56BDA8E7E28A68BA0F26AA7EC0 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35422303161209 Original Product code: 0572174 Bluetooth ID: 002548918BE1 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35422303161209-6 Product Code: 0576443 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! | |
04-08-2010, 16:00 | #12 (permalink) |
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | AUUU MR.SELF CONFIDENCE( ANGEL ) YOUR ARE HERE AS Bonga_2010 TRYING TO HACK MR.HASNIAN IDEA SUPPORTERS YOU HAVE TO CHECK THIS |
04-08-2010, 18:12 | #15 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: ...............
Member: 1104369 Status: Offline Sonork: 78954213 Thanks Meter: 14 | thanks Hasnain successfully repair nokia e71 SIMLOCK_TEST failed! online with Hasnain Quote:
please help me | AVCITHETCNC | NSPRO | 4 | 04-09-2010 15:44 |
wiza200 tmobile help me full unlock | amin1999 | HTC & PDA WM( With Touchscreen) | 1 | 04-09-2010 03:58 |
plz help me its very urgent | lloydgsm | SETool2 | 6 | 04-08-2010 21:59 |
hElp mE Hasnain | nadim_mobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 04-07-2010 17:54 |
