02-16-2010, 05:50 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: MX-KEY is the BEST NOKIA TOOL
Member: 965510 Status: Offline Thanks Meter: 8 | HELP ON 3110 comntact service SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35641802830605-2 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356418028306052 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF wri |
02-16-2010, 06:27 | #7 (permalink) |
Insane Poster Join Date: Feb 2010 Location: Bangladesh Age: 36
Member: 1224463 Status: Offline Sonork: Kafi_ctg Thanks Meter: 26 | 1st of all go to service menu then click pm tab n then click super sd auth...n then load modify pm write it without 120 n 308..post result...best of luck.. |
02-16-2010, 06:34 | #8 (permalink) |
No Life Poster Join Date: May 2006 Location: Gojra
Member: 279362 Status: Offline Sonork: 100.1594141 Thanks Meter: 500 | 1:write pm 2:make simlock rpl repair 3:make sd rpl repair 4:make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model your problem solved |
02-16-2010, 06:40 | #9 (permalink) |
Member: 965510 Status: Offline Thanks Meter: 8 | showing his Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 117.254.158.128 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
02-16-2010, 07:41 | #12 (permalink) | |
Freak Poster Join Date: Jan 2005 Location: (•̮•)
Member: 109758 Status: Offline Sonork: 100.1579682 Thanks Meter: 24 | Quote:
02-16-2010, 07:43 | #13 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | Quote:
help on 3110 | appu2009 | Nokia Base Band 5 ( BB-5 ) | 1 | 12-21-2009 15:11 |
HELP ON 3110 comntact service | appu2009 | Nokia Base Band 5 ( BB-5 ) | 12 | 12-09-2009 06:43 |
help me 3110 contact service | chiku1245 | Cyclonebox | 7 | 11-28-2009 08:10 |
All data OK but contact service on 3110 | Riteshgpt60 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 10-06-2009 07:18 |
