Help 3110C dead Processing file: rm237__07.21.mcusw RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 1E70020FACC86E56FA201D379B3F4EBF0338AAB4 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Programming MCU ... FlashImage: rm237__07.21.mcusw [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.594 s CMT NOR area [000006C0-0001FFFF] erased in 0.063 s CMT NOR area [00020000-0007FFFF] erased in 0.125 s CMT NOR area [00080000-000DFFFF] erased in 0.140 s CMT NOR area [00100000-001FFFFF] erased in 0.266 s CMT NOR area [00200000-0031FFFF] erased in 0.297 s CMT NOR area [00320000-0105FFFF] erased in 3.078 s CMT NOR area [01060000-01067FFF] erased in 0.063 s CMT NOR area [01068000-0107FFFF] erased in 0.062 s Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responded, please check BSI, cable/pinout ! Error while programming [00] at 0x00020300, Result: 0010 Last OS error: The operation completed successfully Flashing terminated with error(s) in 11.515 s RX Buffer: C7012D0103CD000010000000F172 i use Bsi R 3.3k , 5.1k , 7.5k , 10k result same with jaf bus check CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 1E70020FACC86E56FA201D379B3F4EBF0338AAB4 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: D:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 881C0020 <=> ST -> M39L0R807 <=== different flash id detect CMT Flash Data: 00000000000000000000000000000000 CMT Loader: D:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg Loader version: 01.0C.05 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready any solution? thanks |
use usb cable is good and fast |
wbr |
can u open phone ? please check by hardware side. coder willl check from soft side if have wrong info :) br, |
don't re hot your phone,just use usb cable your phone will be ok |
bro try to flash with UFS+HWK....cable should works fine |
bro this is MX-KEY forum not UFS he need help in MX-KEY. Flash ur Phone with USB cable using Dead USB Option. Thanxs |
i try usb flashing : Quote:
You have to go in hardware section. When hardware is not correct software can't do anything. Br. Vijendra Saini. |
flashing with MX-key with jaf interface : Quote:
Reball TAHVO may solve the problem. |
may be its hw p |
