06-30-2010, 12:21 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Lahore - Pakistan
Member: 475308 Status: Offline Thanks Meter: 32 | Secuirity code problem Can anyone have solution how to open code.I have used test mode adapter cables also. If there is a easy way please tell me. Thanx in advance |
06-30-2010, 12:42 | #2 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1292147 Status: Offline Thanks Meter: 11 | bro use hwk first check then info then give full factory defaults it will appear full factory failed then press disconnect then again connect then press full factory defaults try 99% ur security code removed B.R JANGID |
The Following User Says Thank You to ..::JANGID::.. For This Useful Post: |
06-30-2010, 13:12 | #4 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | @babarsmughal just formet drive c security will autometically reset |
The Following User Says Thank You to rakesh15 For This Useful Post: |
06-30-2010, 13:26 | #5 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Any way to remove security codes in 5530-5230 N97 with out losing data?? I tried almost 7 times with mx-key but can't read code Also soft don't show write option in user code option!! Also tried powered on phone with 10 minutes after(coz sometime code blocked with wrong tries) So, any solution for this regards AzeeM !! |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
