help 5130c contact service i have backup rpl and pm help i have a nokia 5130c after flashing it started showing contact service i have the backup rpl and pm from jaf auto backup i tried writing the rpl with jaf it was successfull but pm was not successfull this did not change any thing i copied the pm and rpl to mxkey i tried restoring the imei on mxkey it showed successful but no change pls help me i am in a mess what do i do Powering the phone... Writing PM... Field: 308, Record: 1, Len: 8192 -> Error: Need SX4 auth.. Done! Scanning RPL file... NPC DATA OK... VARIANT DATA NOT FOUND... CCC DATA OK... HWC DATA OK... NPC APE DATA NOT FOUND... VARIANT APE DATA NOT FOUND... CCC APE DATA NOT FOUND... HWC APE DATA NOT FOUND... SIMLOCK DATA NOT FOUND... SIMLOCK KEY DATA NOT FOUND... SUPERDONGLE KEY DATA NOT FOUND... CMLA KEY DATA NOT FOUND... WMDRM PD DATA NOT FOUND... Connecting to phone... FAST PHONE detected! CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Writing NPC DATA... Writing CCC DATA... Writing HWC DATA... Restarting phone... Done! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1BB0010FE54F7F56D7DD19DE962831CE61BC1D42 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Original Imei: 35524603802004 Original Product code: 0572176 Bluetooth ID: 0025D0DD1020 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.90 23-09-09 RM-495 (c) Nokia Imei plain: 12345610654321-? Product Code: 0572176 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! SIMLOCK_DATA corrupted! |
Repair SD + PM auth + Pm + Pm (1 - 309) + Factory Setiings = Full 5130 |
Imei plain: 12345610654321-? |
i think there should be a solution since i have backup rpl and pm ? |
Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.90 23-09-09 RM-495 (c) Nokia Using cached productData[1BB0010FE54F7F56D7DD19DE962831CE61BC1D42] ... Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 SERVER: IMEI number null, empty or invalid (12345610654321?)! any help from any body pls? |
if there is back up rpl before contact service you can solved this other wise no solution |
sir your logs shows SIMLOCK_DATA corrupted, 5130c is an sl3 phone, so sad to say its not yet supported |
exp : repair SD........ bla-bla-bla remember : SL3 simlock can't restorable maybe you can restore simlock using this trick restore simlock from backup JAF. but first U must change the format PM to RPL simlock.. hope will help U.. CMIIW. SCTEAM |
hi all pls can u pls tell me how to restore with the back up i got from jaf auto backup before the 5130c had contact service still waiting |
i have 1 nokia 5130 phone that phone sho coantservice pls help me sl data is currepted |
Till now no solution.. because nokia 5130c is sl3.. sl3 unlocking is no not possible (till now). |
brother this is sl 3 phone mx key not released ...waiting plz |
bro plz wait for sl3 unlocking............:rolleyes: |
