10-26-2010, 06:45 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | help after bb5 downgrade fix imei now 12345 help all a customer game me a 6120 that does not check or flash but when i do scan the info displays, so after so i discovered the sd was invalid i repaired it successfully,and could be able to flash the phone after flashing the phone started showing phone startup failed,i did flashed and formated but but still the same,so i decided to do bb5 downgrade fix after that,the imei changed to 1234 i tried writing imei but it tells me no imei backup,i copied the imei backup from ....af and wrote on mx-key no success,what do i do? logs below Phone Type: RM-243 (Nokia 6120) SW Version: V 06.51 04-02-09 RM-243 (c) Nokia Imei plain: 35484602647890-7 Product Code: 0547708 ApeCoreSw: 06.51 ApeVariant: rofs_version_inforofx_version_info ApeTest: rm243_ENO_x_2008wk49v0.370 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SECURITY_TEST passed Imei net: 354846026478907 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF flashing log Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm243_07.20_prd_core.fpsx as MCU [BB5,XSR 1.5] size: 43.63 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103, 4003192101051105, 400C192101051105 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 571C882 RAP SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] RAP EM0 ID: 00000295 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 1100010D117900521907BBC274DA5AEDECFF6CFA RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE RAP ROM ID: 4B9B75103E691FF8 [ADL] Flashing CMT Update Server Data, ULO: 0x3BC0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, XSR: 0x2107E3 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 1FAD132F [ADL] Verifying communication to device OK. Partitioning.... Partitioning complete Erase size: 74.81 MB Flash programming ... CMT PAPUBKEYS: 0FE1BA92D924A658E4800780FA6F4868100AC947 (RAP Certificate 68 v1) written. Programming completed in 1 min 40.641 s Processing file: rm243_ENO_A_2009wk15v0.100.fpsx as PPM [BB5,XSR 1.5] size: 1.41 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103, 4003192101051105, 400C192101051105 Erase size: 3.00 MB Flash programming ... Programming completed in 3.594 s Processing file: rm243_07.20_prd_vB05_01_russian.fpsx as CNT [BB5,XSR 1.5] size: 23.76 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103, 4003192101051105, 400C192101051105 Erase size: 27.00 MB Flash programming ... Programming completed in 58.250 s [ADL] Restarting phone ... [ADL] Polling for ADL device [ADL] Device found: nmwcdc\Nokia 6120 classic USB Generic, ID: 37324748 [ADL] Verifying communication to device OK. Flashing completed in 3 min 47.469 s Phone Type: RM-243 (Nokia 6120) SW Version: V 07.20 05-10-09 RM-243 (c) Nokia Imei plain: 35484602647890-7 Product Code: 0547708 ApeVariant: rofs_version_inforofx_version_info Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SECURITY_TEST passed Imei net: 354846026478... Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 3 min 51.156 s Nokia USB ROM detached. corrupt imei Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010) Boot error: 02 FF 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Phone Type: RM-243 (Nokia 6120) SW Version: V 07.20 05-10-09 RM-243 (c) Nokia Imei plain: 12345610654321-? Product Code: 0547708 ApeCoreSw: 07.20 Last edited by tonywireless; 10-26-2010 at 06:55. |
10-26-2010, 06:53 | #2 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: FENI,BANGLADESH Age: 38
Member: 537829 Status: Offline Thanks Meter: 96 | Quote:
if u have rpl back up then write it. 100% tested. | |
10-26-2010, 07:05 | #3 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | do i need to be online to write backup or it can be offline?when write rpl this is what i get Imei: 35484602647890 Boot error: 02 FF 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Certificate programmed successfully ! and when i click on restore imei i get this Easy Imei restore for BB5 phones started. Boot error: 02 FF 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Looking for backup for this phone ... No backup found! pls hellllllllp |
10-26-2010, 07:23 | #5 (permalink) | |
make sure ur in bb5 flatform. then go to imei & security then write rpl back up. if u face any problem then use mxkey 3.4 rev 1.3. best of luck. | |
