06-24-2010, 17:18 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | First In Mx 1616 Cross Flashed with 1800 Firmware here is the old log for 1616 Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Sending Secondary Boot Loader ...OK Boot mode: CC EBL version: 10.19, Default_RAM_Bootloader Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Phone Type: RH-125 SW Version: V 04.65 24-04-10 RH-125 (c) Nokia Imei plain: 35272304098532-8 Product Code: 0588617 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IC Language Pack: - not available. TimeStamp: 2010-02-01T03:39:58Z SW Version: 03.61 Variant Version: 001 ProductProfile: RH125_0588617_03.61_001.spr Simlock: 0588617_SimLockDataVerifier_vDCT4.sim Imei net: 35272304098532 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN here is new log 1616 as 1800 , Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Sending Secondary Boot Loader ...OK Boot mode: CC EBL version: 10.19, Default_RAM_Bootloader Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Processing CODE:hw_b2_rm653_r03.600.fls from file rm653_003.600 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 30.828 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 30.594 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.016 s Checksum OK (0xDC4C) Processing CUST:hw_b2_rm653_003.60ic.fls from file rm653_003.60ic Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 28.438 s Checksum OK (0xA754) Processing CUST:hw_b2_rm6530_nai03.60ic.fls from file rm6530_nai03.60ic Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 4.828 s Checksum OK (0xE263) Flashing completed in 2 min 26.094 s Phone Type: RM-653 SW Version: V 03.60 26-03-10 RM-653 (c) Nokia Imei plain: 35272304098532-8 Product Code: 0588617 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IC Language Pack: - not available. Imei net: 35272304098532 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 2 min 38.234 s |
The Following 6 Users Say Thank You to WAJID PNR For This Useful Post: |
06-24-2010, 17:35 | #2 (permalink) |
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | How to flash X-GOLD/Infineon devices(1202,1616,1800, etc) ? first select correct model then select flash file then u can able to "bus check " or 'Scan " option otherwise u cannot use these two button for -GOLD/Infineon devices(1202,1616,1800, etc) phones |
The Following 10 Users Say Thank You to WAJID PNR For This Useful Post: |
06-25-2010, 06:08 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | @ktkwajid Bro, which cable you used for flashing? Can we use normal FBUS cable? Br, Shadab Ahmad |
The Following User Says Thank You to [Shadab_M] For This Useful Post: |
06-25-2010, 16:31 | #8 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Delhi & NCR (INDIA)
Member: 800668 Status: Offline Sonork: 100.1590720 Thanks Meter: 882 | @shadab_a4u Try with JAF interface if you have or which model you are flashing. Br. Shashank |
The Following 2 Users Say Thank You to shashankmobile For This Useful Post: |
06-26-2010, 15:48 | #13 (permalink) | |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Even selected MCU and all other files. I think old 1661 (RH-122) cable will not work with it. Need some modification. Did you flashed with normal FBUS cable which we use for 1661? Br, Shadab Ahmad | |
06-26-2010, 15:54 | #14 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Quote:
me too facing same problem can not bot 1202/1203 rh-111 with normail gpg fbus cable, alrteady try with Easy cable but no luck till now.. | |
The Following User Says Thank You to himanshu taldar For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
