Help Me, 1208 RH-105 Imei ?????????? Phone Type: RH-105 SW Version: V 5.71 12-09-08 RH-105 (c) NMP Imei plain: ??????????????-? Product Code: 0549881 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MD Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN I can't write RPL in online logger because BootLoader not responding, mostly RAM problem ! Help Me, :confused::confused::confused: |
Just Use Free DCT4PLUS IMEI in Service => IMEI & Security => Online Logger all will be ok. IF mostly RAM problem ! then check Cable or Box. or change Bootloader folder from Config => Flash Update Directory. Good Luck |
Help Me, :confused::confused::confused: Any solution for my problem:confused::confused::confused: |
Use JAF box as MX KEY interface to solve it or if you have not JAF box then Manually collect RPL & write through HWK |
there may be a problem in hardware gan .... |
what interface do you use ? UFS with HWK ? if not false,you can do BUS check and get original IMEI ( UEM IMEI ) from phone with HWK or use MXKEY old version :( then do manuall calculation and write that RPL br, |
just flash v5.6 ok your problem or [email protected] |
